SuperiorLakeEffect
Bronze Member
So sometimes when snowblowing, I forget about that switch under the seat, and stand up or shift my weight enough to cause the PTO safety switch under the seat to kill the tractor.
But here's the weird part, after doing so- it can be difficult to get the tractor restarted. I don't think it's the safety switch, as the tractor will crank, but acts like it has a low battery- cranking really slowly and the solenoid clicking if I try to much.
If I go get the truck and jump it, it'll start no problem.
This doesn't happen all the time, and if I let the tractor sit for a bit, sometimes the problem will go away (sometimes I think it isn't actually the jump that fixes it, it's just the time it takes to do so).
I can turn it off immediately after that and it will restart on it's own no problem.
I've made sure the HST is in neutral, clutch in, PTO disengaged, and relieved the pressure in the loader lines to no effect.
Sometimes I think I should just zip tie that switch, but I do this often enough that it's probably a good idea to leave it as is.
Any ideas?
Any ideas?
