axle under springs?
/ axle under springs? #1
jimmysisson
W.Mass
1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
Like many trailers, the single axle on my utility trailer (former electric Co. 3/4 ton job) sits over the 7-leaf springs. Any harm in flipping it over so the spring saddle is under the springs, like on a pickup? I could see there's a longer lever arm when traversing a side hill, maybe stressing the shackles more? Any other objection? Trailer's about 20 years old, straight axle, light frame, heavy springs. I'm trying to get the bed higher off the ground.
Thanks, Jim
/ axle under springs? #2
That's a common mod on fifth wheel RVs to raise it up when towing with a 4X4. Dexter axle even sells a kit to do it. I had it done to my camper and it's been fine in the 8 years that we've had it. Google Dexter axle.
/ axle under springs? #3
jimmysisson
Is it an on road trailer?
Axels have a chamber (bent up slightly in the middle). this is so when it is Loaded they are straigt. That makes the wheels slightly at the top
If you flip the axel over it will reverse the camber
as RobS sait you can change it but you have to keep the axel in the same orentation.
tommu56
No, I'll only use it off-road. Not sure if the camber matters much at 5 mph?
Jim
/ axle under springs? #6
/ axle under springs? #7
I just had my trailer axles moved to below the springs to raise the trailer. It's a job I should have had done before I brought the trailer home.:D :D
/ axle under springs? #8
Do'nt forget if the head on the center bolt is round you will need to reverse it as the nut will not fit the hole in the spring saddle . Also on a side note , as i was looking for springs and axles to build a Gooseneck lowboy . I found the carrying capacity is downrated if the springs are below the axles as oposed to above . The only reason i can think of is that the "U" bolts would be carrying the load in the underslung version .
2022 EZ-GO ELITE...
(4) BF Goodrich All Terrain Tires (A65563)
(4) BF Goodrich...
Saddle Tanks (A65640)
1967 Hyster C35T-3 Equipment Trailer (A66285)
1967 Hyster C35T-3...
2022 SWARTZ 100" X 40' GOOSENECK TRAILER (A64276)
2022 SWARTZ 100" X...
Quick Attach Backing Plate (A65579)
Quick Attach...
