Axle straps
/ Axle straps #1
alexinPA
NE PA (Lackawaxen)
Kubota B7800
I posted this in another thread (dump trailers), but no replies. Any adventages/disadventages in using axle straps to tie down a small tractor? The reason I want to use'em-limited space in my 12' dump trailer. Anybody?
/ Axle straps #2
As long as there are no sharp edges to cut the straps, it should be fine.
I have thought about using them on the front axle and a chains on the rear.
/ Axle straps #3
I have 4 of them in my trailers tool box. They work just fine but I use them mainly on cars, not tractors. I have used them on tractors from time to time.
Chris
/ Axle straps #4
I use them on my tractor and when I haul my jeep. They are as stong as the straps. And if you get a bad spot in one they are cheaper to replace than a new strap.
/ Axle straps #5
Call me paranoid about safety, but I prefer to use chains and rachet binders whenever I am hauling anything larger than an ATV or a lawnmower.
/ Axle straps
Chris
Chris, when you used them on tractors, the center of gravity is higher then on cars. Did you just used 4 axle straps? Any additional straps/chains?
AK
/ Axle straps #7
AK
I just use them where it needed. For example I transported a freshly painted 8N for a friend. No way I was going to wrap chain around it so I secured the tractor with two in the rear and then hooked to the brush guard in the front.
Chris
/ Axle straps #8
Chris
If you keep cotton rags handy to put under them, chains won't scratch the paint.
/ Axle straps #9
I have had the opposite experience. I have uses old floor mats and conveyer belt but towels and rags have ate though and done damage. Does not matter though because I am properly prepared.
I have in my tool box on my trailer:
2 J Hooks like a tow truck uses
4 10' Grade 70 5/16" chains
2 boomer
4 10' ratchet straps rated at 10,000# (3,333# break)
4 25' ratchet straps rated at 10,000# (3,333# break)
4 18" axle straps
2 Jack Stands
3,000# winch
8 plastic strap edge protectors (Like Truckers Use)
Chris
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
JMR TREE BOOM (A61572)
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
DIXIE-NARCO CFT-54 COCA-COLA DRINK COOLER (A64276)
DIXIE-NARCO CFT-54...
Galvanized metal roof Vents (A64194)
Galvanized metal...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
