Axle spring seat welding
/ Axle spring seat welding #1
ericher69
Ontario Canada
2008 Kubota b2920
Don't know if this is the proper term for these things?
http://www.google.ca/search?tbm=isc...&q=axle spring seats&sa=N&biw=320&bih=306#i=9
Anyway need to weld some on a 3500lbs drop axle for a trailer.
Any special considerations or prep I should do?
I am going to :
1. grind off paint from axle
2. Degrease seats and axle
3. Line up and clamp
4. Tack
5. Recheck
6. Then burn in with Lincoln SP170-T with .030 wire and CO2 (230V 3/8 capacity)
Material (seats 1/8) and axle same
7. Prime
8. Paint
9. Reassemble
Do you think I should chamfer the seat to get better penetration?
/ Axle spring seat welding #2
Should work the way you have it.
Bolt everything in place with weight on the spring perches then tack in place. Pull it apart and burn then as planned.
E/S
Don't use brake clean to degrease.
E/S
Will not be able to put weight on with springs as the axle has been brought to me without trailer
Should not be an issue
/ Axle spring seat welding #4
I did this same thing a few years ago for a guy. I placed the axle on my welding table, with crown up. Placed the seats so far in from the wheels and used a torpedo level on each seat for alignment / rotation.
He's gonna leave the existing ones in place so I figure a nice flat surface like concrete should do
Will place new ones and use angle/tubing to true up/clamp and tack
Will take pics
Here is the final product
Here are some similar links:
