Axle position
/ Axle position #1
Nightowl66
NW. Ohio
Kubota B6200DT
I bought this tilt trailer cheap, has 3500lb axle, going to paint put in a floor and new tires.
The axle is 3 1/2" to the front of the center of the trailer bed. Normally the axle is to the rear. Being a tilt trailer is this why the axle is more forward?
Has little tongue weight. I only pulled about 15 miles to home. And pulled ok. Just worried about it towing without swaying.
/ Axle position #2
I have a small single axle tilt trailer. The axle is about 60% of the bed length back, just like most non-tilt trailers. Other commercial ones I've seen are the same.
I've seen several home-builts like yours. The builders wanted them to tilt easily, or on their own, and stay down while loading.
Bruce
/ Axle position #3
Depends on what you are hauling. If there is too much weight behind the axle it will sway.
/ Axle position
Thanks for the replies. According to the calculations online on axle placement, it should be moved back approximately 4 1/2 inches. I don't know if it's worth going to the hassle of doing that I guess I will just be careful when I load the trailer or just add weight to the tongue
/ Axle position #5
Could you mount a spare tire on the tongue or a tool box?
Loading problems should be minimized since you know to load heavy in front.
/ Axle position
I'll just mount a spare tire upfront. I'm not going be traveling long distances, if I do my four wheeler will be in it and it will be up towards the front anyways
/ Axle position #7
It's place there to allow the tilt angle to be such that something can actually be loaded.
If it were mine is would move it back and fix the trailer to a non-tilt trailer.
Chris
/ Axle position
Chris
That's what I've decided to do.
/ Axle position #9
Smart move. Easy to do now in the condition it's in.
If I may ask, what did you pay for it and what do you expect to put into it?
Reason I'm asking is I will buying a 5x10 this week. I can get a new one with 3 way gate, 3500# axle, LED lights for $944.10 to my door.
I looked forever for a used one but I was only finding beat up ones or ones needing new boards, tires, paint, ect for the $700 price range
Chris
/ Axle position
I paid 150. Going to put new wood, tires and rims. Maybe putting 400-450 in it.
/ Axle position #11
Man, that's a deal. The axle is worth that much.
People in my area are ridiculous. I went to look at a year old 5x8, really wanted a 5x10, that the guy was asking $750 for. It needed new lights and a fender. I walked. He called me and said he could do $700 but no lower. I looked up the trailer and a local dealer had them for $799 new or 3% off for cash so about $775.
They all think they have gold!
Chris
/ Axle position #12
Sounds like California pricing...
Do you have a link to the $944.10 trailer...
Don't like much using the 12k PJ to move the RTV...
/ Axle position #14
Sold only in the East... story of my life.
Great price...
2013 VOLVO ECR88 (A65643)
2013 VOLVO ECR88...
100-gallon L-shaped Portable Fuel Tank (A66408)
100-gallon...
Mccormick Farmall Cub Tractor (A65579)
Mccormick Farmall...
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
Bush Hog 114 3Pt Mower (A66408)
Bush Hog 114 3Pt...
