Axle position
/ Axle position #1
Nightowl66
NW. Ohio
Kubota B6200DT
I bought this tilt trailer cheap, has 3500lb axle, going to paint put in a floor and new tires.
The axle is 3 1/2" to the front of the center of the trailer bed. Normally the axle is to the rear. Being a tilt trailer is this why the axle is more forward?
Has little tongue weight. I only pulled about 15 miles to home. And pulled ok. Just worried about it towing without swaying.
/ Axle position #2
I have a small single axle tilt trailer. The axle is about 60% of the bed length back, just like most non-tilt trailers. Other commercial ones I've seen are the same.
I've seen several home-builts like yours. The builders wanted them to tilt easily, or on their own, and stay down while loading.
Bruce
/ Axle position #3
Depends on what you are hauling. If there is too much weight behind the axle it will sway.
/ Axle position
Thanks for the replies. According to the calculations online on axle placement, it should be moved back approximately 4 1/2 inches. I don't know if it's worth going to the hassle of doing that I guess I will just be careful when I load the trailer or just add weight to the tongue
/ Axle position #5
Could you mount a spare tire on the tongue or a tool box?
Loading problems should be minimized since you know to load heavy in front.
/ Axle position
I'll just mount a spare tire upfront. I'm not going be traveling long distances, if I do my four wheeler will be in it and it will be up towards the front anyways
/ Axle position #7
It's place there to allow the tilt angle to be such that something can actually be loaded.
If it were mine is would move it back and fix the trailer to a non-tilt trailer.
Chris
/ Axle position
Chris
That's what I've decided to do.
/ Axle position #9
Smart move. Easy to do now in the condition it's in.
If I may ask, what did you pay for it and what do you expect to put into it?
Reason I'm asking is I will buying a 5x10 this week. I can get a new one with 3 way gate, 3500# axle, LED lights for $944.10 to my door.
I looked forever for a used one but I was only finding beat up ones or ones needing new boards, tires, paint, ect for the $700 price range
Chris
/ Axle position
I paid 150. Going to put new wood, tires and rims. Maybe putting 400-450 in it.
/ Axle position #11
Man, that's a deal. The axle is worth that much.
People in my area are ridiculous. I went to look at a year old 5x8, really wanted a 5x10, that the guy was asking $750 for. It needed new lights and a fender. I walked. He called me and said he could do $700 but no lower. I looked up the trailer and a local dealer had them for $799 new or 3% off for cash so about $775.
They all think they have gold!
Chris
/ Axle position #12
Sounds like California pricing...
Do you have a link to the $944.10 trailer...
Don't like much using the 12k PJ to move the RTV...
/ Axle position #14
Sold only in the East... story of my life.
Great price...
2011 OVERLAND TANK 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2011 OVERLAND TANK...
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
16ft. Aluminum Extension Ladder (A65640)
16ft. Aluminum...
Heavy Duty Pipe (A62679)
Heavy Duty Pipe...
2022 Kaufman Trailers Trailer, VIN # 5VGFW5035NL009932 (A65563)
2022 Kaufman...
