Axle nut
/ Axle nut #1
Kodiak45
SC
long 2460 - belarus 250 - JD 4230 - Kioti DK40SE
Any tips on getting this 2.75"axle nut off. I've soaked with oil and used small propane bottle to heat and this thing won't move. Last one I took off another disc was removed with torch. Would it be easier if I removed the gang from the frame. If I take my torch to the farm, I'll end up cutting it off and probably ruin the axle threads. I haven't tried a cheater bar yet, just a big 24" pipe wrench.
/ Axle nut #2
If it is frozen that tight a cheater bar may shear the axle.
I would split the nut to get it off.
/ Axle nut #3
Just helped my brother do this last week! Wrap a chain repeatedly around the disks up unto the gang so it won't turn eventually, heat the nut and BIG ***** cheater pipe. It will come, but you may need to buy a new nut.
/ Axle nut
I might as well go ahead and order another nut. Even if I split the nut, won't the threads be too damaged to put another nut on?
/ Axle nut #5
Perfect place for the 50/50 mix of Acetone, and ATF. Amazing stuff..!! Put it on 2-3 times a day for several days. Then as mentioned, wrench & big cheater. Had to do this several years ago on mine.
/ Axle nut #6
I always have much more luck with impact than cheater bars. I would use Kroil for several days, and an big air impact.
/ Axle nut #7
Using a cheater bar runs the risk of damaging the threads on the axle. Split the nut on opposite sides will preserve the threads on the axle and only take about 1/2hr.
/ Axle nut #8
I always have much more luck with impact than cheater bars. ...
And if I didn't have a big impact wrench, I would use a flat-end punch and hammer to turn the nut. Maybe a little cold chisel application on the flats and the bottom of the slots to try to expand it a few thousandths and break loose the rust bond.
I wouldn't use a pipe wrench by choice. They will squeeze the nut tighter against the bolt while trying to turn.
Bruce
/ Axle nut #9
yup.. that is begging for a 3/4 or 1" impact after a good penetrant soaking.
/ Axle nut #10
If you don't have, or have access to a large impact wrench...... I have used a 48" pipe wrench on the nut with a large adjustable wrench on the other end. this was after soaking it and giving it a few licks with a sledge hammer...:laughing: A 24" wrench just ain't gonna cut it. Put a long enough cheater on it and just break the wrench, been there done that. That's when I bought the 48" wrench from HF.
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
FORD 6610 TRACTOR (A59823)
FORD 6610 TRACTOR...
1999 John Deere 7810 (A60462)
1999 John Deere...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
