Aw nuts.. Engine pops after stall
/ Aw nuts.. Engine pops after stall #1
jnjpream
Berthoud CO
BX22
I had tilled about 1/4 acre and and found piece of old iron and before I could react it stalled the tractor. Talking a fraction of a second. I got off, pulled the junk out of the tines, and fired it back up. After that I noticed a popping when WOT under load and hot. I was mowing the next day it seems to be lacking some power too.
What should I be looking for? Blown head gasket? I don't see any signs of burning anti-freeze. I did refuel not long before the stall too but have never had a fuel problem before. Bent valve? Worse?
/ Aw nuts.. Engine pops after stall #2
depending on the size of the tractor
first , check the timing with a strobe light ... if it's not right , pull the flywheel and check the "key" that locks the wheel to the crank ... it may have partially sheared ....
if timing is correct, check the compression ( low compression points to a bent con rod and retarded timing too )
very unlikely for head gasket or valve damage .....
don't overlook "bent" drive pieces putting a strain on the motor ...
/ Aw nuts.. Engine pops after stall #3
Once you get the engine all straightened out, go back and check your tiller's slip clutch or shear pin.
Whichever overtorque protection you have didn't do it's job.
Hope your engine issue is a minor one!
832728 (A61166)
832728 (A61166)
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A61567)
2025 BrushFox...
2009 Genie TZ-50 50ft Towable Articulated Boom Lift (A61567)
2009 Genie TZ-50...
2014 Aerway Aerator (A55973)
2014 Aerway...
