SmallChange
Platinum Member
- Joined
- Apr 19, 2019
- Messages
- 777
- Tractor
- New Holland WM25 with 200LC front end loader, filled R4 tires 43X16.00-20 and 25X8.50-14 (had a Kubota B6200D with dozer and R1 tires)
I just removed the urethane lip on my bucket edge, which was held on by 5 half inch stainless bolts. One of these went from spinning freely to absolutely welded together as I unthreaded the nut, and had to be cut. How do I prevent this?
They were fine thread nuts and bolts, which I now read is a bad idea. Also I did not use anti-seize lubricant, which would have helped. I could also have used, say, 304 bolts with 410 nuts, which would have been better.
But is stainless just the wrong choice? What kind of nut and bolt would you use to attach a urethane edge (or perhaps a tooth bar)? Zinc plated steel perhaps?
