Auxiliary Hydraulics
/ Auxiliary Hydraulics #1
ramdigger
Perkasie, Pa
Case 580C
I just got a new backhoe attachment for my ASV RC100, hooked the lines up but the bucket only tries to move one way, both buttons on the joystick have a reaction when pushed and 1 hose moves from hydraulic pressure but the bucket doesn't move...... The cylinder is at the end of travel.... This machine is new to me and it's the first time I've used the auxiliary hydraulics...... Am I doing something wrong or overlooking something ?? Any input would be appreciated
/ Auxiliary Hydraulics #2
Sounds like one QD is not fully connected.
Reset and try again.
You can plug in a hyd gauge in the QD and activate the button and see if you have pressure.
Thank you for your reply. I don't have access to a gauge to plug into the QD, but I did try working with one line hooked up at a time and the top one is definitely not working. Can I remove the QD safely to see if fluid pumps out? Do the QD's go bad?
/ Auxiliary Hydraulics #4
Yes, just remove the QD and use a hose in a bucket to check flow.
You can switch hoses also.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
We do NOT accept credit cards as payment. (A64127)
We do NOT accept...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
2008 21 Ft. Sea-Doo Speedster Boat with 2008 22Ft. Karavan S/A Trailer. (A61574)
2008 21 Ft...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
