Auto Function On PTO ??
/ Auto Function On PTO ?? #21
Well Kioti doesn't seem to go overboard with the safety interlock stuff. You can even stand up out of the seat and press the hydro pedal to see the tips of your forks going into a pallet:) Can't do that with a Kubota. yeah the rear three point is dangerous, but only if you are careless.
True enough. I suppose I would rather have the option to use those features and trust myself not to use them improperly, than not have them because the designer does not trust me.
It's funny, but I had the same thought about running the transmission with my hands when I was hooking my backhoe up this weekend. Thought against it, but can't guarantee that I won't next time.
/ Auto Function On PTO ?? #22
I do worse than that. I can stand next to the tractor and operate the HST with my hand while lining up an implement. Very useful for hooking up the backhoe.
Shh..I wasn't going to mention that..:)
/ Auto Function On PTO ?? #23
Try moving the tractor back and forth with the FEL instead of the HST I think that would be safer when hooking up.
/ Auto Function On PTO ?? #24
IslandTractor said:
Why do you turn the PTO off when turning while tilling? I leave it running and just raise the tiller at the end of a row with 3pt controls then drop it again after turning.
Steep angle of drive line causes the drive line u joints to wear out.
/ Auto Function On PTO ?? #25
I actually dont use the auto feature much either. I do use it with the rototiller cause i forget to shut it off when i lift the tiller at the end of the row. So here the feature is nice, but then i have to idle back down to re-engage so i dont see much use. Too bad they didnt engineer some sort of automatic slow engagement feature. now that i would use.
but as to the original post, no i have never had any issues with the switch working as its supposed to . it does shut down when i lift and restart when lowered.
/ Auto Function On PTO ?? #26
I can see that would be a problem with continuous use but for the five or ten seconds it takes to line up for the next tilling pass it shouldn't be a problem.
/ Auto Function On PTO ?? #27
IT, you're just a madman! Danger must be your middle name. LOL. :laughing:
/ Auto Function On PTO ?? #28
The key is to watch where you foot is.. Don't run the tire over it:laughing: with the tractor at idle, and in low range, when you push on the hydro pedal, it just crawls.. an inch worm goes faster. Keep you bucket flat on the ground, and don't do this unless you are on flat ground.
/ Auto Function On PTO ?? #30
Hey, I still have a few toes left. We don't swing from trees anymore so losing a few is no biggy.
Seriously, it is hard to line up something fussy a Woods BH without being able so control tractor placement within quarter inch or so. I think it is also dangerous to be leaning out backwards over the top of the operator station while "seated" with your foot on the HST pedal too. And, as Koua has noted, a motivated snail could out run the tractor in low reverse with just a bit of pressure on the pedal with fingers. Much less likely to slip than with the "leaning out backwards" position.
/ Auto Function On PTO ?? #31
My B26 will move a few inches to a few feet depending on the gear and RPM when you press the HST pedal while not setting in the seat before the safety kicks in and starts to kill the engine. I like it that way rather than engine dying when you raise off the seat for a millisecond. I hate the NH set up that have to put in neutral range to get off the tractor or start. Most of the time I just leave my B26 in H range which is what I use for transport to and from the storage area and just crank and go.
Just recently I discovered that my LS P 7010 would stop the PTO by clutching (deeply depressing the clutch). I had thought that it couldn't be feathered in because clutching to stop would still auto start in manual mode or auto mode but I just wasn't depressing the clutch far enough to disengage it. I don't suppose the HST guys have anything like that although I do see some models of HST that still have a clutch which is a good thing IMO.
WRT the auto feature, I rarely lift up my bush hog (only PTO implement I have)when turning or backing up so the auto feature is not an issue with me.
/ Auto Function On PTO ?? #32
Just finished tilling the garden and alpaca lot and love the auto function for tilling and then backing up with the tiller up and PTO off. Great for low inertial equipment but needs a warning label to turn off before dismounting the tractor. With the motor running and adjusting the 3pt from the rear can startle one when the PTO kicks in.
Many of the newer tractors have remote raise/lower controls on back of tractor. This, in combination with Auto PTO, is a serious accident waiting to happen.
My 2 cent opinion.
Rick
Calf Creep Feed Hut (A66408)
Calf Creep Feed...
American Flag Sign (A64127)
American Flag Sign...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
Truck Tool Box (A65640)
Truck Tool Box...
1998 International 4700 Flatbed Dump (A62613)
1998 International...
2016 GMC Sierra Flatbed Truck, VIN # 1GD42WC83GF101701 (A65563)
2016 GMC Sierra...
