Auto-darkening helmet
/ Auto-darkening helmet #21
I've come to realize that I need a curtain on the backside of the helment to block light from coming in. It just helps me see better. I need to find some cloth that is really fire and spark proof.
/ Auto-darkening helmet #22
I've come to realize that I need a curtain on the backside of the helmet to block light from coming in. It just helps me see better. I need to find some cloth that is really fire and spark proof.
Generally cotton is what is used as it merely smolders with no flame.*
I seem to have read that soaking in a solution of alum renders cotton fire proof.
Synthetics burn, melt and drip hot melted plastic.
*Have a few Levi jeans that will attest to that, LOL
/ Auto-darkening helmet #23
My first helmet was the HF auto and apparently it was defective. I returned it after trying it a couple times and bought the cheapest Miller ($99 I think). It has been flawless and even better now with installed cheaters. I hang it in the window of my shop when not in use for a while to charge the solar panel. Nice and lightweight and I feel more confident than going with the HF but I suppose that is because of my bad luck on my first one.
Fool me once, shame on you. Fool me 3-4 take back the same defective item, shame on me? :)
/ Auto-darkening helmet #24
Yes, and preferably with no fussy nap. I sure use to light up those Green Ape gloves.
This is going to be one of those 'be nice to have in case I need it purchases' instead of an 'I need it to use right now purchase'. Kinda makes me feel like my wife buying a pair of shoes on sale just because they are on sale and not because she needs them. You all know what I'm talking about, "Honey, look how much I saved by buying these!"! When I actually don't need it. But the last time I started to weld something the lens was broke on the helmet and I didn't have time to go get another so I drilled holes and bolted the brace back together. It really needs welding. Plus I've got to repair the deck on the 45-year old Ford bush hog I use or a chunk will get throw thru the top right into my back. After reading some of the comments for the second or third time I think I will look for a helmet with easily replaceable AA or AAA batteries that are easy to put in and take out even if that helmet costs a little more. For use two or three times a year that would work best for me.
Thanks for all the info.
RSKY
/ Auto-darkening helmet #26
I bought the HF auto-darkening helmet last year. I've used it maybe three times, and it seems to work fine. I don't do a lot of welding either, so learning that RK has one with replaceable batteries has me rethinking the HF. All of my welding stuff is in a cabinet in the garage, but the helmet sits on top to get light to recharge. Would be nice to put it away with everything else. Thanks for the heads-up, RSKY. (pun intended)
/ Auto-darkening helmet #27
had a Harbor freight auto helmet and it was pretty dark for Mig -also once I started tig welding it would sometimes flash me , especially when welding small parts at low amps.
I bought an Antra AH6-260 4 sensor helmet fully auto on off for about $45 from amazon and it has been great almost 2 years of use no problems or even battery replament needed.
It has a grind mode, and has replaceable batteries , is also solar powered.
It accepts cheater lenses and also has a test mode, sensitivity adjustment and delay control fast 1/25000 second dimming response and also has a 2 range selector 4/5 - 9 for plasma cutting and acetylene and 9-13 for most stick and Mig.
Also comes with 6 replacement outer lenses , batteries included and Tig rated down to 2 amps
has over 750 reviews is their Best seller a 4.5 rating for $45.95
I bought the Fusion from Rural King today. It has two replaceable button batteries and a solar charge. It was $39.95. Was gonna look some more but my wife liked the Stars and Stripes coloring with the eagles head....... Yeah, I know, but we've been married 43 years.
Oh, and she bought a pair of shoes today.
It just occurred to me, could that be why she wanted me to go ahead and buy the helmet?
I fear that I have been MANipulated.
RSKY
/ Auto-darkening helmet #29
:laughing::laughing: wive's get pretty good at it after a few decades don't they:D
/ Auto-darkening helmet #30
Or...ma-nipple-lated! I don't mind that a bit.
/ Auto-darkening helmet #31
I will add one more data point. I have used a cheap HF auto dark helmet for about 4 years. It's still working and the rechargeable battery seems to be holding up. However, I get annoyed at the inadvertent darkening from work lights and I find it's a little hard to see the puddle and see exactly where the arc is.
I decided to spend some money ($200) and I got a Lincoln Viking 2450 helmet. It has a much larger window, the "4c" technology with 4 light sensors. Excuse the pun but it's like day and night. I can see so much clearer now it's amazing.
No question that the cheap helmets will work but if you intend on doing much welding, spending more will make the experience much more enjoyable. I'm not under the illusion that it will make me a good welder (that would be a miracle) but now I can see that I'm making a mistake much faster.
/ Auto-darkening helmet #32
Hahahaha Ain't that the truth! The auto-darkening helment did not improve my welding techniques very much. I still can't see what I am doing very well unless I have a super bright light focused on where I am welding. I'm not sure if the shade is to dark or if it is light infiltration from the back of the hood reflecting back into my eyes.
Most often, my weld just wanders away... kinda looks like chicken feet, most of the time. Gonna try a blackout shroud and see if it helps.
/ Auto-darkening helmet #33
I completely agree i wandered off course with my dads amazon special helmet several times because i could not see clearly. Been flashed when welding in weird positon and the sensor was covered.
The Lincoln covers a huge shade range. I liked the miller interface but the lincoln lens technology
Another case of you get what you pay for.
/ Auto-darkening helmet #34
Quote: "I bought an Antra AH6-260 4 sensor helmet fully auto on off for about $45 from amazon and it has been great almost 2 years of use no problems or even battery replament needed.
has over 750 reviews is their Best seller a 4.5 rating for $45.95"
Just got that one myself, so far seems like a bargain for $46. Antra AH6-26- Solar Power Auto Darkening Welding Helmet with AntFi X6-2 Wide Shade Range 4/5-9/9-13 - Arc Welder - Amazon.com
/ Auto-darkening helmet #35
/ Auto-darkening helmet #36
I have a HF one. It hangs on the tank valve on my mig welder. When I touch the mig wire to the steel without pulling the trigger it makes a small spark that's just enough to force the lens to darken. It's probably 10 years old now and has never failed to work. The biggest issue with it is the protective lens is plastic so splatter does stick to it on occasion and when it gets covered in smoke and dust if you are not very careful you will scratch it. Those scratches take their toll making the puddle harder to see. Now that I'm getting older and my eyes need a little help I'll probably replace it with something nicer with a thinker plastic protector lens (or glass) so I can just replace the glass at will. I'm also going to get something that I can use a cheater lens with.
/ Auto-darkening helmet #37
The plastic cover lenses are sacrificial and are available at any welding store in a variety of sizes, pretty cheap, too. Lot of places really go through them.
/ Auto-darkening helmet #38
Well the OP has already done his deal. But for other readers mine has the grinder setting as mentioned by one or two others. I use the grinder setting often. A trip to the eye doctor tends to make one more careful. I also keep it in a plastic bag so as to keep the dust and what not out of it. Less scratches on the lenses and no bugs etc etc. auto darken is sure nice to have. And ya I still have the head nod habit at times even though I have had the hood for years.
/ Auto-darkening helmet #39
For a bit more money about $100
Some of the Guys over on Welding Web are really liking this
HTP Striker Supreme XL
Striker Supreme XL Welding Helmet, Welding Gun Accessories, Metal Working, Welder Supplies | USAWeld.com
Quoted from a post
(I bought one when they were on sale for Father's day and I love it a LOT. The head gear is a little wonky but visually it is stunning. Best view of the puddle I have ever had on any helmet. It is 1/1/1/1 rated. Super impressive visual acuity.)
a description of the ratings of clarity
offers excellent protection and unbeatable clarity
in fact, earned an optical clarity rating of 1/1/1/1,
the best possible optical clarity rating for auto-darkening welding lenses.
Graded on a scale of 1 to 3, with 1 being the best grade and 3 being the worst,
the Striker Supreme XL achieved excellence in all four classes of optical clarity—
optical (or accuracy of vision),
diffusion of light,
variation of luminous transmittance,
and angle dependence on luminous transmittance.
This sounds really good if my antra bites the dust or I need an even clearer view of the puddle.
/ Auto-darkening helmet #40
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
40' Shipping Container (A66285)
40' Shipping...
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
