Austrailian built McCormick
   / Austrailian built McCormick #11
As long as you're having fun Mate.
Were you south enough, the other week, to get snow?
Not quite, we are inland a bit from the Sunshine Coast.
You lot can keep that white stuff down there, we dont need it.
Though a bit of rain would be good, its getting bloody dry. Going to be a bad fire season with all the long grass around.
   / Austrailian built McCormick #13
I didn't cop any snow either, but St Helens is the "Riviera" of Tassie. I have had my pipe from the tank freeze twice this season... just had to wait 'til 1030 to have a tubs. (Note to self: see if there's some pipe lagging in town)
The cold has led to a shortage of hay as the local stock are eating more than usual.
It was 3 degrees C on the verandah this morning. Thats too cold for here. We only have four horses on 40 acres so still have plenty of tucker.
Still need rain but.
   / Austrailian built McCormick #15
Now to clean the inside off the block . Sleeves must go in freely before you install the o-rings with liquidsoup . Remember to apply a bit of silicol in the topstep of the block to assist with sealing .
Yep, just waiting on my rebuild kit to arrive. It comes with new gudgeons and big end shells as well.
I was wondering if putting silicon sealer on the O rings would be an idea. It would act as a lube for the liner and seal as well.
I thought of putting a dab in the top too.
   / Austrailian built McCormick #17
Liquide soap on o-ring and bottom part of sleeve....no silicon there ! Silicon will harden and float and block your coolingsisteen .
After installing sleeves use topbolts and a nut that fitts on it to clampdown the sleeves when installing the pistons and rings .
The combustinchambers should not protrude from the top(silinderhead)
Thanks for the tips. I gather you have done this before.
At first I thought a PCC had dropped down a bit but on cleaning the head , it is pitted around it. I gather water must have been leaking in there at some time.
   / Austrailian built McCormick #19
Hi
On checking the photos of the silinderhead it looks to me that the glowplugs is connected wrong ? There is two steps (connectingpoints) on one glowplug And to connect all of them you need to connect no 1 and 2 and then no 3 and 4 (big eyes on the lead )and then the isolators on all 4 glowplugs after that you add the next connection between 2 and 3 and then the power at no 4 and the earth at no 1(all smaller eyes on those leads). But before that you will have to pressuretest the silinderhead for any cracks . They crack normaly between the PCC and the valveseats . Replacing the silinderhead is a good idae but if not avalable then stitching must do .
In the gasketset you get 8 big copperwashers , 4 with a bigger ID , use them with the old ones to lift your PCC to let your piston clear the PCC when you start the engine for the 1st time.
You are very observant:)
The glow plugs are Toyota ones and made to be connected like that.
Supposed to be an improvement in that if one craps out the other 3 still glow. Not like the original system.
The adapter is locally made and sold on ebay here.
24in pin on excavator tooth bucket (A56435)
24in pin on...
3410 (A47477)
3410 (A47477)
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
Hose Reel (A55758)
Hose Reel (A55758)
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
