Auger Adapter
/ Auger Adapter #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I have a general brand one man auger. I bought it used from a home depot rental location. I would like to use it for ice fishing this year, but my auger shaft outer diameter is 1 inch, and the ice auger inter diameter is 3/4".
i cant seem to find and adapters online, and recommendations?
/ Auger Adapter #2
You might have to make one...:2cents:
/ Auger Adapter #3
No problem for anyone with a lathe. Local school shop? Machine shops don't generally like small jobs, not enough $ for them.
/ Auger Adapter #4
You could take piece 1" pipe and use a bushing to size down. Or buddy with a lathe.
/ Auger Adapter
what pipe material would you recommend?
/ Auger Adapter #6
I would use black iron/ black steel pipe from home depot or the hardware store .....
/ Auger Adapter #7
Water pipe (aka. "black pipe") is not true to size. 1" pipe is slightly larger on the ID and about 1 1/4" on the OD. 3/4" pipe is >3/4" on the ID and >1" on the OD. You'll probably have to do some file work to make it fit.
Find someone with a lathe that will make one. It's like a 15-minute job including cutting the stock. Heck, I'd do it if you were closer.
/ Auger Adapter #8
Yes, a lathe would be the best option. The pipe idea is something that could be figured out and made with basic tools. Drill press is the only real specific tool need for the centering of location pins to hold onto the auger and bit. Hopefully someone one here has a lathe that is close enough to help out. Good luck with the endeavor.
2019 Harley-Davidson FLHTP Electra Glide Motorcycle (A66738)
2019...
2007 CAT 140H MOTOR GRADER (A67714)
2007 CAT 140H...
Bomag Roller (A63689)
2026 KH72 72in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A66734)
2026 KH72 72in...
Fuel Storage Tank (A68134)
Fuel Storage Tank...
2015 Honda Accord Sedan (A66738)
2015 Honda Accord...
