ATV Trailer build
/ ATV Trailer build
This is where I want them to go. Sorry about the squiggly lines but it's gets the idea across. Am going to use the same 1x2 .090 tubing for the braces. I don't think the axles will flex much when done.
/ ATV Trailer build
/ ATV Trailer build
Would it be strong enough if I came from the a 90 deg angle off the cross brace instead of the corner? That would be a heck of a lot easier to cut.
/ ATV Trailer build #64
Only thing better than triangles is pyramids. ;) I'd make the compound cuts myself.
/ ATV Trailer build #65
I hate the slag cleanup
Have you tried coating where you will be welding with nonstick cooking spray? ("Pam" and its generic equivalents)
There are also commercial products made just for this, but the cooking spray seems to work for many people and is cheaper and easier to find.
/ ATV Trailer build
LOL never heard of that. Does it keep the stuff from sticking?
/ ATV Trailer build
Not gonna make this easy huh? King Tut here I come! Gotta make a Dr visit this AM, then get some supplies. I ordered the ball coupler, since no one within driving distance carries that size, so I will get all I can to complete it up to that part. I have a hard time getting rid of some stuff, especially metal, and a couple years ago I changed out my small boat trailer from 1 7/8 to 2", but did I keep the old one?? Noooo of course not. :(
/ ATV Trailer build #68
Cooking spray is just as good as anti-spatter spray sold for welding, but way cheaper.
When you fit up your braces, make them guide anything under the axle stubs or towards the open center. You want it to be smooth so the trailer rides over anything it might encounter instead of catching on it.
/ ATV Trailer build
OK made some more progress today. I gotta say those compound bevels are a PITA. I cut them by hand, since there is no way this brain was going to calculate how to do it otherwise.
Here's one side
And here's the other
This is how the end of the axle stubs looked. I later ran a small bead where the braces join the axle stub, mostly to keep water out, since structurally the axle isn't going anywhere.
Looking down from above. This is what you'd see if the bed were removed.
This is it in tilt mode.One thing that came back to me AFTER I had one side welded up. NOW I know why I had my self talked into just running the braces straight out from the frame, instead of angled, like I ended up doing them. When I went to dump the bed, the braces hit the tongue braces, preventing full motion. :mad: Jim this is all your fault........ Just kidding. The logic of strength was good, but I needed to move the braces outboard about 1/2" for clearance. Sooooo, the grinder became my friend. I have almost full range now, but need a little more trimming. I grind off the corners where they meet. I actually got to thinking I will grind a little more and am might put some stops on the braces to save my paint later.
I did some more research on MIG welding and watched some more videos, and got a bit more education. I tried what I learned and got better results than I had before. I still have about 5-6lbs left on my solid wire spool, so when I can get some gas I will try to build something using only MIG.
/ ATV Trailer build
Don't look too closely at my welds. Due to my advanced cutting techniques on my compound bevels, I had to piece in some small pieces to fill in where I inadvertently "removed" parts I shouldn't have. When I break out the 7" grinder, it will get a lot better looking. :) I figure if it weren't for guys like me, people would start to think EVERYONE on here was a perfect welder and machinist. I just help keep it real! :)
I need to use something to cover the holes in the axle stubs. I got some flat plates but they didn't have any that small, so I either need to cut these down, or do something else.
Also, will have to wait for the ball coupler. Tracking says somewhere between Feb 4-9. I hope it's earlier. I THINK I want to finish the tops of the side rails, to allow me to add sides for tall brush, but that idea is waning.
I also need to start building the door frames for front and rear, then sand down the whole thing to ready it for painting.
/ ATV Trailer build #72
You should already be on the hottest setting for the machine, but try turning down your wire speed just a touch and see if you get a better puddle.
After not having a 120v welder for over a decade, I got one again and my first instinct was turn up the wire speed for more heat - only it didn't have enough juice to run the wire that fast. When I backed it down, I got a much better arc and much better puddle.
/ ATV Trailer build
Thanks. It might have gotten bumped. It's real touchy in that respect and I often forget to check it. Usually it barely reaches 3 on the dial. I have been eyeing the Everlast 200, but it would prob be a year before I am even close. Oh well, there's worse things.
/ ATV Trailer build #74
3 doesn't mean anything to me, but neither would wire speed not knowing what your voltage and amperage actually were too. I've found running a bit longer arc works better with the smaller machines. What I can get away with on my big welder would end up with really cold welds on yours. The more wire speed I push, the more amps the power supply delivers. 120v welders just don't have the power to do that.
/ ATV Trailer build
Yea I get that, it's on a scale of 1-10. No idea how many IPS it is, I just know it will push the wire a LOT faster than it can melt it. :) It's not much of machine, as welders go, but I've had and used it for over 10 years (and yes I am still that bad :) ) and it keeps doing all I ask of it.
I go in spurts. SOmetime I lay down welds that look like something from a text book, and sometimes not! It's about a 60-40 split, of bad/good. I did notice something in one MIG video, the tip was protruding out from the shield, about 1/4", but mine is recessed. When the stickout is only supposed to be 3/8 to 1/2" inch and the tip is recessed, you cannot see what you are doing. Are there different length tips?
/ ATV Trailer build
Not using one. The bed is balanced over the axle to it's just a matter of tipping it up to dump. It has a bracket on the tongue of the trailer with a quick pin through it to keep it in place when loading or transporting.
I got it sanded today and painted all the black parts (tongue, and axles and braces underneath) with the first coat. Will wait till tomorrow afternoon to put on second coat of black. I left the front 8" or so, sanded bare, so when the ball coupler arrives, I can weld it in place and get it painted. Once the black is done, I will mask it and do the orange. When that is done I will have a rolling chassis at least. Still waiting back from sheet metal shop for a quote. I am going to wait till I get the sheet metal on before I build the front and rear end panels. I want to make sure they fit with the sheet metal installed.
Won't be looking for a tight seal, I am more concerned with making them too small before metal goes on.
/ ATV Trailer build
/ ATV Trailer build #79
There's different length tips, and you can get rid of your nozzle if you want with the flux core (doesn't serve any purpose other than maybe helping you guide the tip), but you also want a little more stickout with the flux core wire.
I tend to run a short stickout and a shorter tip with a longer than ideal nozzle. I just get right up in there to where I can barely see the puddle in the gap, but when I started I had a lot of stickout (probably too much). Eventually, you just figure out what works best for you and go with it. The arc/puddle should be your guide.
/ ATV Trailer build
Yea I always remove the nozzle when using flux. I will try to get some various length tips when I fill the gas up, and experiment.
On a REAL good note, my ball coupler that wasn't supposed to arrive until at least Friday, came today. Tomorrow the wife has a minor surgery in the morning, and not sure what after that will be. I will at least get a second coat of black on it. I haven't gotten a 2" sq tubing piece yet, and unsure if I will be able to tomorrow, so it might be Friday before I can get that and install the coupler.
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59914)
2023 KENWORTH T680...
2018 CAT 259D Skid Steer (A62613)
2018 CAT 259D Skid...
2025 JMR 4x8 Forklift Safety Basket (A61572)
2025 JMR 4x8...
