atv tires
/ atv tires #1
canden10
gt5000 craftsman
Where can I find knobby atv tires to fit my GT5000 Craftsman Tractor? The stock turf tires can't make the terrain, about 4 acres of sloping and rough ground. The tractor seems to have plenty of power, but just needs tires that grab and use all that horsepower.
/ atv tires #2
Try WalMart, TSC, or even Craigslist if you what size you want on there for cheap.
/ atv tires #4
I bought "V" style tread tires from Carlisle for mine. They work very well and show no wear after 7 years use.
/ atv tires #5
I would recommend chains. More traction on more surfaces.
/ atv tires #6
Chains are good, but they sure do alot of damage to the driveway.
I remove my chains before I even go on the driveway, they almost dig up the old blacktop. :(
/ atv tires #7
carlisle v-tread can be had from TSC or nearly any tractor dealership for about 35-45$ each.
/ atv tires #8
I don't think TSC offers Carlisle anything any longer. Check out treadepot.com.
/ atv tires #9
Not when used on a lawn mower.
/ atv tires #10
Ebay is your friend...they have a lot of different types, have a look at the attachment, is shows a R1 tire made for lawn tractors.
Ivan
/ atv tires #11
I bought my 95 wheel hores new and it had chains on it as it was winter when i got it. I have never taken the chains off. 16 years later, still on the tractor and the tires still look new.Great traction for every use including mowing.
/ atv tires #12
I have Carlisle knobby tires on my Snapper and there great. They keep it going where turfs just would not. I mow ditch's and along my raised drive that always where a problem. Running them at 5psi so it ride's great. I've had bar tires on my last tractor and like these better. Got mine at a local Fleet Farm for less than a hundred for the pair. No blacktop damage or lawn damage. My Simplicity getting some this year.
/ atv tires #13
I just dealt with this very issue. Look here: http://www.carlisletire.com/media/catalogs/catalog.pdf
Find the section with AT 101 Chevron. I think it is page 15. They are basically "Ag" or "Bar" tires for your riding mower. I installed mine this past weekend on my riding mower.
/ atv tires #14
Keep in mind issues with tire height and clearance. I replaced with Chinese direct replacement size flat tread? (tire is supposed to be flat across). At 12 psi the tire center domed out enough to rub on the mower deck when raised. Most ATV tires have a substantial dome.
/ atv tires #15
I have Duro Excavator tires on my ATV. Relatively cheap, and awesome traction. This is another Duro ATV tire "Buffalo" - looks like it would make a great lawn tractor tire.
I buy my ATV and motorcycle tires at a regular tire place. They don't have the greatest prices in the world, but order their bike/ATV from the Parts Unlimited catalog, and their standard pricing formula gives basically dealer price. I suspect this is not unusual.
JayC
/ atv tires #16
ATV tires work awsome on a garden tractor. My buddy has a 3000 series Cub Cadet like me and can snowblow with no chains. He says the do minimal damage to grass, they were cheaper than bar tire garden tractor tires.
I would like a set myself for hills in my yard,the turrf tire rips up more when it spins than they do.
He bought carlisle tires and they are a radial.
mail order shadetree.com has alot of atv tires or denniskirk.com
or try a local powersport dealer they may be a ***** to mount at home
/ atv tires #17
ATV tires are absolute cake to mount. Literally takes all of about 2 minutes. WAY easier than dirtbike tires, I'll tell you that. You will need to break the bead of the old ones - that might be tough if you don't have a bead-breaker:
Bead Breaker
JayC
/ atv tires #18
Bead Breaker
JayC
FEL works a treat.
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59910)
2019 ISUZU NPR 4X2...
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
WOODS 14' MOWER DECK (PARTS ONLY) (A63290)
WOODS 14' MOWER...
M&W 4310 LITTLE RED GRAVITY WAGON (A63745)
M&W 4310 LITTLE...
