ATV Electrical problem - need help
   / ATV Electrical problem - need help #11
What Kenmac said. It is your grounds. Don't just look at them. Take them apart, clean them and put them back on.
Thanks all - I think it has to be the ground also. After playing around with it for a while today everything is testing good. I have two thoughts - bad ground and some current is bleeding over and giving me a false positive. I am going to rewire it and put a lot of new connectors on it to eliminate some of the possible problems. Thanks again and soon as I get a little time free I will work on that ground. I appreciate all the help!
   / ATV Electrical problem - need help #13
Relays are the weakest link in many systems. The points arc and connectivity is lost over time. Both up and down can be affected since the paddle probably swings from one side to the other.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2013 John Deere 824K (A51039)
2013 John Deere...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2000 KOMATSU VALMET 860.4 FORWARDER (A51222)
2000 KOMATSU...
