Atv drawn flail mower
/ Atv drawn flail mower #1
dieseldoc25
Luray, VA
Ford 8N and 1970 Deere 4020
Good evening all,
Just wondering if anyone has one of these things. Pow-r-kraft atv drawn flail mower. I bought one on a whim ($1695 shipped to me in Virginia from Oregon). The next closest is a good bit more expensive.
I bought a 59 inch cut and it is powered by a knock off Honda engine.
Anyone have one? Anything I should plan on upgrading? I am going to use it behind my 3010 diesel mule. I have a 44 inch swisher rotary I use for my small mowing now as well as a 60 inch swisher finish mower. I am going to replace both with this. I have a zero turn for my lawn and a 10 foot schulte rotary for the big mowing. Just need something small for our walking trails and such around the property.
Thanks!
59? Gas Flail Mower, PK-AT145E | eBay
/ Atv drawn flail mower #2
I bought an Alamo fail mower, commercial grade, with the Honda red engine. The first thing I found was that the 12" wheels were way too small for field or trail work. It appears to be designed for mowing parks and ball fields. So I put on some much bigger go cart wheels to raise it up a bit. But the front lip still would catch on clumps of grass and cause it to flip over. So we put a ball-type hitch and reinforced the tow arms. Still would catch and flip, spilling gas and catching fire [to itself and the grass] all while the 80 chain knives kept whirling -- not a good situation. I never even made it to a real trail because it was obviously not going to work.
The other thing I found was that it is very hard to hold an ATV at a steady pace. Turing corners or starting up a hill it would bog down [Honda 450 ES] and when you added more throttle it would zoom ahead. and its not a comfortable as a tractor or even lawn tractor since there is no back to lean on.
I hope you have better luck but I had to conclude that ATVs aren't tractors and mowing is for mowers.
/ Atv drawn flail mower #3
I would look hard at adding another 2-3 feet to the tongue of it, otherwise it will be almost impossible to back up...
Aaron Z
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65057)
2001...
(INOP) 2005 CATERPILLAR 535B SKIDDER (A65056)
(INOP) 2005...
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A68842)
ALLMAND ECOLED-RIG...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
2017 Peterbilt 320 New Way 20ASL 20yd. Side Loader Garbage Truck (A66736)
2017 Peterbilt 320...
X (A68191)
X (A68191)
