atv cc?
/ atv cc? #11
Try to find one with a low range in the transmission. My Polaris Sportsman and Magnum both have an low range.
Is your land already broken and you just want to till it every year? I had Craftsman pull behind tiller that I tried to use on a garden plot that hadn't been turned in two years. Failed miserably, didn't have enough weight to break thru and just bounced along. Rented a walk behind and had it done in no time. I find most tow behind implements don't work very well. If you only need to do it once I'd just rent a tractor or pay a neighbor.
/ atv cc? #12
I had a Artic Cat 500 with a 3 pt hitch that had a electric actuator for down pressure. I rigged a one bottom plow from a garden tractor plow, the 500 automatic pulled the plow good if the ground was not too dry. I think the 3 pt hitch was made by cycle country
/ atv cc? #14
I did a lot of plot work with a Polaris 500, 600 and 800 with a 5 bottom chisel plow I built. Things were tough and the ATV's complained. Later I bought a 25hp 4x4 utility tractor with a 5' disc and never looked back. Plus with a loader, it does all your heavy lifting too. What ever you have is good because you are putting in plots, but once you do it with a tractor you will be home.
2014 RAM VAV 2000 TRAILER MOUNTED VACUUM MACHINE (A59823)
2014 RAM VAV 2000...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
12' Truck Box (A60352)
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
2020 Kinze 3505 High Speed 6/11 Planter (A61307)
2020 Kinze 3505...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
