ATTN: B3030 Owners
   / ATTN: B3030 Owners
Thats a fair question. Kubota really does not sink money into the seat on many of their tractors. Its defentialy a product worthy of a nice seat!
   / ATTN: B3030 Owners #22
MessickFarmEqu said:
$750! You must have called a parts counter. The markup (From a dealer & Kubota) is much higher over the parts counter than it is though the wholegoods Dept. MSRP on that seat from wholegoods is $360. You'd probably have to be charged the UPS fee's as well.
Where in the wholegoods pricebook did you that price?
Bill
   / ATTN: B3030 Owners #23
It's a tough balance between offering the best of everything and keeping the price reasonable.
   / ATTN: B3030 Owners #25
I shimmed the front six bolt of the seat suspension. That brought the front of the seat up 1-1/2", leveled the seat right out for me & made it more comfortable. Cheaper than buying a $300.00 seat and didn't have to mess with any wiring for the safety switches under the seat. Took 15 minutes to fix
   / ATTN: B3030 Owners #26
Could you post a picture of that shim job piperflyer. Thankx in advance, Scott.
   / ATTN: B3030 Owners #27
Kioti has upgraded their standard seats on the CK20/CK25/CK30 to a suspension seat. I imagine it is about the same as the on Neil is talking about as a retrofit seat costs about $650.
My CK20 is pre2005 so has the old style seat. Sure would like to upgrade but $650 is almost as tough to swallow as $750.:mad:
   / ATTN: B3030 Owners #28
Here is a picture of the seat shimmed, gained close 1-1/2" on the front end. I just used some nuts I had laying around that were bigger than the stud bolts already on the seat frame. I slipped them over the stud bolts that Kubota uses for the frame.
#1 you need four bolts over the studs
#2 you need two bolts on the front adjusting rail
#3 you need two bolts on the front of the seat frame mount
If I had some metal and a band saw I would of made a wedge out of the metal and mounted it under the seat frame in #3 from front to back.
Pull the seat off with the front pin removed, easier to work on
   / ATTN: B3030 Owners #29
Thanks for the photos, im going to try the shimming before i shell out hundreds of dollars for a new seat.
   / ATTN: B3030 Owners #30
The way it's shimmed now is temporary. When I get some time I'm going to make two metal wedges and install them under the seat frame. It will be more professional looking and I can cut the wedge to the seat height I want.
2023 CATERPILLAR 299D3XE SKID STEER (A51242)
2023 CATERPILLAR...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
Caterpillar Front Glass (A50854)
Caterpillar Front...
2014 Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
2014 Lay-Mor...
