Attacking that power problem CT225
/ Attacking that power problem CT225 #151
Sounds normal to me.
It's normal for mine. :laughing:
It definitely doesn't like going up steep (20%) hills in high and not so keen on medium either. I usually change to low for them.
/ Attacking that power problem CT225 #152
When negotiating hills, do you press the HST pedal all of the way forward or just part way?
/ Attacking that power problem CT225 #153
No, if anything you let up on the pedal. I believe that that is why many HST owners-users do not like HST transmissions, they don't quite get how that they need to be used, and end up getting frustrated. :eek:
/ Attacking that power problem CT225 #154
MtnViewRanch,
Could you please explain how letting up on the pedal improves hill climbing ability?
/ Attacking that power problem CT225 #155
As you push down on pedal to increase speed is equal to shifting into a higher gear in gear transmission machine. Letting off the pedal to slower speed is equal to 'down shifting" to a lower speed that will increase torque through the drive system and require less horsepower to get same job done.
/ Attacking that power problem CT225 #156
SSdoxie,
Does the increase in torque happen in all three ranges?
/ Attacking that power problem CT225 #157
SSdoxie,
If you mean by letting up on the pedal do you have more power in each range, then yes that is how it works. ;)
/ Attacking that power problem CT225 #158
The HST pedal controls volume of oil flowing out of the pump to the HST motor which then turns the gear box & differentials (determines speed). The pressure required to move depends on the load, resistance to move. Flow @ pressure determines the horse power required from the engine. When trying to do a specific job and engine starts to labor, reducing the flow (let up pedal) reduces the HP requirement to engine.
Quick example: I don't know what full pump flow capacity is but I'll use 15 GPM as example.
At full pedal 15 GPM, if load resistance requires 3000 PSI = 26 HP from engine to move. If you let up on the pedal to flow @ 13 GPM at 3000 PSI load= engine only needs to put out 22 HP to move the tractor.
/ Attacking that power problem CT225 #159
My brain is wired poorly for topics like this.
I'm sitting here really trying to grasp this concept.
Don't I need MORE power to get up the hill? If I had a 40hp or 50hp tractor would I still need to let-up on the pedal?
/ Attacking that power problem CT225 #160
At a certain point of weight to horsepower you do overcome it. But other wise to down shift a hydro you let up on the petal.
2023 CAN-AM HD7 RTV (A59823)
2023 CAN-AM HD7...
John Deere 568 Megawide Plus Round Hay Baler (A60462)
John Deere 568...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
2015 Jeep Patriot SUV (A59231)
2015 Jeep Patriot...
DEUTZ MARATHON...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
