attachments that require front hydraulics
/ attachments that require front hydraulics #1
Lowcountry Rebel
Ravenel S.C.
TYM 603
what type of attachments need front mounted hydraulics- I'm in the sunny south so don't need a snow blower.
/ attachments that require front hydraulics #2
I have two such front mounted attachments. The bucket and the grapple on my front end loader(FEL). OR you might be considering a front mount rotary cutter or snow blower - both mounted on the FEL.
/ attachments that require front hydraulics #3
I installed a set of front remotes mainly for a thumb grapple....but I also use them to power a hydraulic winch that is mounted on skids that gets chained to a tree...I have a set of 20' hoses...
There are "4 in One" buckets that have hydraulic clam shell closures...also they can be used for a hydraulic MMM lift I think...?...
/ attachments that require front hydraulics #4
Grapples, 4 in 1 bucket, bale squeeze, front mounted blade to mention a couple.
/ attachments that require front hydraulics #5
Hydraulic angle on a snowplow, fence post puller.
I was already planning on a grapple and a 4 in 1 loader bucket, a fence post puller will probably pull up medium trees, I will check on a front mounted rotary cutter- it might be really handy for clearing work.
Thanks for the ideas
/ attachments that require front hydraulics #7
Typically the front mounted rotary cutters require a lot of hyd flow and a pto power pack may be needed for optimal performance. Grapples and hyd post hole diggers I’d say are the most common
Brett
/ attachments that require front hydraulics #8
On a skid steer the possibilities for hydraulic implements are nearly endless. In a tractor you’re mostly limited to stuff that doesn’t have hydraulic motors. The flow isn’t there for any amount of power.
/ attachments that require front hydraulics #9
you can run smaller things like a limb saw quite well at under 10GPM. but something like a hydraulic snow blower... nah, not happening with tractors our size with a power pack driven off of the PTO I believe you will need something like 25GPM for that.
/ attachments that require front hydraulics #10
Look at skid steer, or Germany Unimog, then you will find out so many front implements need front hydraulic.
/ attachments that require front hydraulics #11
On a skid steer the possibilities for hydraulic implements are nearly endless. In a tractor youæ±*e mostly limited to stuff that doesn稚 have hydraulic motors. The flow isn稚 there for any amount of power.
You can run some front mounted augurs with a tractor hydraulic system: Lowe 75� Hex Auger Drive - Skid Steer Attachment Depot
In addition to augurs and grapples: Tree puller and/or shear.
Example: Tree Fence Post Puller Skid Steer Attachment Quick Tach Bobcat Kubota Case
/ attachments that require front hydraulics #15
The things I own that go on the SSQA and have hydraulics are post hole digger, trencher, rotary cutter, cement mixer, 6 way dozer blade, and vibratory sheeps foot packer.
/ attachments that require front hydraulics #16
Here is one requiring hydraulics, that isn't seen much here on TBN. It is a Tilt-Tach, it tilts 15 degrees to either side:
Don't have pictures with the bucket on it, here it is with the box blade on a 3 point adapter:
/ attachments that require front hydraulics #17
Most tractors are set to a 2,500psi relief on the hydraulics, some a lot lower. Generally unless you go above 60hp you are lucky to get 10gpm, my 40hp L4060 is 9.something gpm.
2,500psi @ 10gpm delivers 14.5hp under ideal conditions. So ya, hydraulics dont hold a candle to PTO HP.
My hydraulic PHD has notably less power & speed than my old PTO PHD did. I still prefer it because of visibiand ity, down pressure & reverse, but wish it (well, my hydraulics really) had more power. Hydraulic angle on my SSQA snow plow is nice too & not really dependent on good hydraulic flow for proper operation.
/ attachments that require front hydraulics #19
I have the grapple, Lane Shark trail cutter and a log splitter. Very pleased with operation of each one. I have 16.2 GPM flow on my tractor and 2 separate sets of hoses/connections mounted on the FEL. One set is from the 3rd function and is used for the grapple. The other has one hose from a rear SCV and the return line to the sump. That one runs the cutter and splitter.
/ attachments that require front hydraulics #20
I can recommend the Lane Shark FEL rotary cutter. Have cleared a lot of yaupon and water-oak sapling thickets with it. Very flexible - several different positions and angles - and can reach up way high to trim planted pines and such. Our Kubota MX5200 runs it just fine with only 9 or 10 GPM flow.
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
2017 Ford F-250 4x4 Crew Cab Medical Service Truck (A61573)
2017 Ford F-250...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
2019 John Deere 9470RX Tractor (A63111)
2019 John Deere...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
