attachments that require front hydraulics
/ attachments that require front hydraulics #1
Lowcountry Rebel
Ravenel S.C.
TYM 603
what type of attachments need front mounted hydraulics- I'm in the sunny south so don't need a snow blower.
/ attachments that require front hydraulics #2
I have two such front mounted attachments. The bucket and the grapple on my front end loader(FEL). OR you might be considering a front mount rotary cutter or snow blower - both mounted on the FEL.
/ attachments that require front hydraulics #3
I installed a set of front remotes mainly for a thumb grapple....but I also use them to power a hydraulic winch that is mounted on skids that gets chained to a tree...I have a set of 20' hoses...
There are "4 in One" buckets that have hydraulic clam shell closures...also they can be used for a hydraulic MMM lift I think...?...
/ attachments that require front hydraulics #4
Grapples, 4 in 1 bucket, bale squeeze, front mounted blade to mention a couple.
/ attachments that require front hydraulics #5
Hydraulic angle on a snowplow, fence post puller.
I was already planning on a grapple and a 4 in 1 loader bucket, a fence post puller will probably pull up medium trees, I will check on a front mounted rotary cutter- it might be really handy for clearing work.
Thanks for the ideas
/ attachments that require front hydraulics #7
Typically the front mounted rotary cutters require a lot of hyd flow and a pto power pack may be needed for optimal performance. Grapples and hyd post hole diggers I’d say are the most common
Brett
/ attachments that require front hydraulics #8
On a skid steer the possibilities for hydraulic implements are nearly endless. In a tractor you’re mostly limited to stuff that doesn’t have hydraulic motors. The flow isn’t there for any amount of power.
/ attachments that require front hydraulics #9
you can run smaller things like a limb saw quite well at under 10GPM. but something like a hydraulic snow blower... nah, not happening with tractors our size with a power pack driven off of the PTO I believe you will need something like 25GPM for that.
/ attachments that require front hydraulics #10
Look at skid steer, or Germany Unimog, then you will find out so many front implements need front hydraulic.
/ attachments that require front hydraulics #11
On a skid steer the possibilities for hydraulic implements are nearly endless. In a tractor youæ±*e mostly limited to stuff that doesn稚 have hydraulic motors. The flow isn稚 there for any amount of power.
You can run some front mounted augurs with a tractor hydraulic system: Lowe 75� Hex Auger Drive - Skid Steer Attachment Depot
In addition to augurs and grapples: Tree puller and/or shear.
Example: Tree Fence Post Puller Skid Steer Attachment Quick Tach Bobcat Kubota Case
/ attachments that require front hydraulics #15
The things I own that go on the SSQA and have hydraulics are post hole digger, trencher, rotary cutter, cement mixer, 6 way dozer blade, and vibratory sheeps foot packer.
/ attachments that require front hydraulics #16
Here is one requiring hydraulics, that isn't seen much here on TBN. It is a Tilt-Tach, it tilts 15 degrees to either side:
Don't have pictures with the bucket on it, here it is with the box blade on a 3 point adapter:
/ attachments that require front hydraulics #17
Most tractors are set to a 2,500psi relief on the hydraulics, some a lot lower. Generally unless you go above 60hp you are lucky to get 10gpm, my 40hp L4060 is 9.something gpm.
2,500psi @ 10gpm delivers 14.5hp under ideal conditions. So ya, hydraulics dont hold a candle to PTO HP.
My hydraulic PHD has notably less power & speed than my old PTO PHD did. I still prefer it because of visibiand ity, down pressure & reverse, but wish it (well, my hydraulics really) had more power. Hydraulic angle on my SSQA snow plow is nice too & not really dependent on good hydraulic flow for proper operation.
/ attachments that require front hydraulics #19
I have the grapple, Lane Shark trail cutter and a log splitter. Very pleased with operation of each one. I have 16.2 GPM flow on my tractor and 2 separate sets of hoses/connections mounted on the FEL. One set is from the 3rd function and is used for the grapple. The other has one hose from a rear SCV and the return line to the sump. That one runs the cutter and splitter.
/ attachments that require front hydraulics #20
I can recommend the Lane Shark FEL rotary cutter. Have cleared a lot of yaupon and water-oak sapling thickets with it. Very flexible - several different positions and angles - and can reach up way high to trim planted pines and such. Our Kubota MX5200 runs it just fine with only 9 or 10 GPM flow.
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
1986 CATERPILLAR D4H HI-TRACK CRAWLER DOZER (A64279)
1986 CATERPILLAR...
2021 BOBCAT T62 R-SERIES SKID STEER (A64279)
2021 BOBCAT T62...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
2025 JMR Stump Bucket Skid Steer Attachment (A61572)
2025 JMR Stump...
2002 CATERPILLAR 247 SKID STEER (A64279)
2002 CATERPILLAR...
