Attachments/Implements - I didn't know?
/ Attachments/Implements - I didn't know? #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
Attachments/Implements - I didn\'t know?
Browsing through the Kioti page and clicked on products. I found a link for attachments and a link for implements.
When I click on attachments I find a loader and a backhoe.
When I click on implements I find aerators, box blades, brush hog, landscape rackes, tillers and so on.
So is an attachment something that has a permanent bracket but removeable such as the loader or backhoe and an implement is something you just hook on to your tractor and go?? I guess always thought there was really no difference.
murph
/ Attachments/Implements - I didn't know? #2
Re: Attachments/Implements - I didn\'t know?
I reckon a hoe could be both as there are 3pt and subframe mount for 3pt type. So I don't know if that's actually a rule. What about a cutter? Think of that as an implement? Mount it to the front or side and it becomes an attachment. Implement for an attachment? Hmmmmm......
Then there are attachments for attachments.
/ Attachments/Implements - I didn't know? #3
Murph, I don't pretend to know the definitive difference, but every "implement" you mentioned can hook to essentially any tractor with a standard 3PH. The "attachments" all require a special adapter for mounting and are semi-permanently mounted.
I can't take a loader attachment off my New Holland and hook it to a Kioti without modification; however, I can take rotary cutter or boxblade and hook them to almost any brand of tractor with no modification. I think that's the difference.
/ Attachments/Implements - I didn't know? #4
Having done some editing for Kioti, I would simply guess that the only reason they have a difference is that someone suggested it sounded better.
John
/ Attachments/Implements - I didn't know? #5
THAT SOUNDS LIKE A VERY GOOD EXPLANITION /forums/images/graemlins/smile.gif Better than anything i could think of and it makes sense also. /forums/images/graemlins/grin.gif
/ Attachments/Implements - I didn't know? #6
I guess backhoe "implement" sounds kinda funny even though most modern are 3pt compatible. Just what we're used to I guess. Probably from the days when they mounted detachable ones to dozers and tlbs
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2018 Hino 195 20ft. Box Truck w/ Electric Liftgate (A64556)
2018 Hino 195...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
2012 FREIGHTLINER M2 6X4 T/A ROLLOFF TRUCK (A66091)
2012 FREIGHTLINER...
213101 (A64276)
213101 (A64276)
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2019 Toro...
