Attaching Winch to Front of Tractor?
   / Attaching Winch to Front of Tractor? #1
future_vision
New England
DK6010SE HSA
This is probably somewhat of a newb question. I have a Harbor Freight winch and was originally thinking I'd have to attach it to the back with a towing receiver or some configuration like that. Then I noticed the front of my tractor has this plate on the front as shown in the image below. Can a winch mount be attached there? If so what would be the best way to mount?
   / Attaching Winch to Front of Tractor? #2
I built an hydraulic winch from scratch and mounted it on the same place. That's where the front weight bracket and weights would go.
In order to reduce the risk of splitting the tractor in half, make sure that sub frame is going all the way to the bell housing and then the loader mounts tie it together with the rest of the tractor.
The biggest issue with electric winches is the duty cycle and the power draw from the battery. Since most of these tractors have either 50 or 70A alternator, it's just not enough to keep up.
   / Attaching Winch to Front of Tractor? #3
I've owned six different 4WD vehicles. They have all had WARN winches on the front. My current vehicle - 2018 Ram 2500 Power Wagon has two 200 amp alternators and a 12,000 pound WARN winch.
400 amps is in no way capable of keeping up with the continuous draw from the winch. The WARN winch under full pull can draw more than 750 amps.
Any long or hard pull must be staged to allow the alternator to recharge the battery. And allow components to cool down.
Just be careful of two things.
- don't fry your battery
- don't burn the insulation off the wires going from the alternator
to the battery or the battery to the winch.
   / Attaching Winch to Front of Tractor? #4
Did you notice the crack in the lower left of that plate?
   / Attaching Winch to Front of Tractor? #5
Sure, you can do anything, but remember electric winches are for occasional "recovery" and not hourly use.... Electric winches are hungry and will kill a battery and alternator if your tractors electrical system is not up to the demands of what the winch needs to function with any success...
Best way to mount.... Put a receiver hitch on front, that way you can use winch on either end of tractor and you can insert a trailer ball or a tow hook or whatever you can adapt to a receiver....
   / Attaching Winch to Front of Tractor? #6
And don't run batteries down to where your computer drops out from low voltage.... You will either have to wait for battery to recover on its own or use jump start procedure to get going again....
   / Attaching Winch to Front of Tractor? #7
It can. Best way is to build a mount for it. Personally, I'd build one that had a receiver hitch underneath it. This, of course, requires that you have steel fabrication tools and skills. Given that you're asking this question, I'm going to assume that you don't, which leaves hiring it done. Doing that is probably going to be fairly pricey. Just depends how dedicated you are to the idea. That said, I'll just reiterate what has been said. Tractors aren't generally set up for large electrical loads, like a winch. They're designed to power things via hydraulic or mechanical means, not electric.
   / Attaching Winch to Front of Tractor? #8
Do you have a bucket on the tractor? Is there clearance around that bracket for the loader?
How much winching are you expecting to do from the front of the tractor?
I built a semi-portable trailer winch. Custom 1 1/2" receiver for the trailer. I know, a little odd, but there are reasons for that. Then on the back side of the winch mount I also added two 1/2" bent round rod loops. It comes in really handy. I've attached the winch to trees, my tractor, a pickup, or whatever else I need to either pull or pull from.
If you have a good battery, you can pull the winch in once or twice without draining it.
   / Attaching Winch to Front of Tractor? #9
I really have doubts on that statement because it depend on size of winch, size of power to operate winch, how stuck you are or vehicle you are rescuing....
I have a Jeep that weighs in at 4500 pounds, with 10,000 (+/-) lb. pull winch in front and have to block all four wheels, and it took two attempts to get 1400 pound (more like 2,200lbs, with FEL and ballast) stuck tractor out of bog.... And Yes Jeep has 950 CC battery and 100 amp alternator and during both pulls I pulled Jeep system battery down to 9 volts (with engine running) and had to back off to recover, because at 8.5 (+/-) Jeep system voltage computer craps out.....
   / Attaching Winch to Front of Tractor? #10
I put a plate with a tie down on mine. Could have been a receiver tube. Used a piece of cardboard to make the template. My bolts weren’t long enough, ordered (I think) 12mm x 1.25 x 45mm, the thread was different than I expected to find.
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
DEMAG ELECTRIC CHAIN HOIST W/ RAIL & TRUCK (A52708)
DEMAG ELECTRIC...
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
JOHN DEERE ROW MARKER 4R TOOL BAR (A58374)
JOHN DEERE ROW...
NEW FRONTIER 4' BOX BLADE (A52708)
NEW FRONTIER 4'...
2015 Dodge Charger Passenger Car, VIN # 2C3CDXAT4FH817483 (A57453)
2015 Dodge Charger...
