At Wit's end, clutch pedal return spring for 455D ???
   / At Wit's end, clutch pedal return spring for 455D ??? #1
DiskDoctr
Platinum Member
Western PA
Mahindra 3510
We have a JD455D crawler loader with the foot pedal steering. The left pedal return spring is broken. I ordered one as close as I could tell and model, but it is far to large diameter and isn't right.
I have searched google, ebay, and any tractor part place I could find online, but no luck :confused:
I've been away so long due to illness that I was pleasantly surprised to find my login still worked!
If anyone can help me find this elusive part, I would be very grateful :thumbsup:
Thanks
   / At Wit's end, clutch pedal return spring for 455D ??? #4
   / At Wit's end, clutch pedal return spring for 455D ??? #6
You can go to the parts site, and look at the parts for the 455D
https://partscatalog.deere.com/jdrc/
Pic of the assembly where I pulled the part #
I saw the drawing you posted, but thought that was the traction clutch pedal, not a steering pedal. I hope that's the right spring! All I could find was lever steering and gave up.
I think you're right.
Here's a pic of the missing spring and its mate
   / At Wit's end, clutch pedal return spring for 455D ??? #8
Since there is plenty of room for a replacement spring, I would take the one you have to a Hardware store and see what you can find. We have Menards locally and they have plenty of springs in their specialty hardware sections
   / At Wit's end, clutch pedal return spring for 455D ??? #9
If all other sources fail; this spring is easy to make on a lathe.
   / At Wit's end, clutch pedal return spring for 455D ??? #10
this is what you're after I believe - (item #13). T14243 is the origonal number, but it subs to T143245
2011 John Deere 4520 53HP Loader Utility Tractor (A51691)
2011 John Deere...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
1987 Ford F-250 Wrecker Tow Truck (A51692)
1987 Ford F-250...
2015 Nissan Altima Sedan (A51694)
2015 Nissan Altima...
