At Home In The Woods
   / At Home In The Woods
My tractor isn't running.
I suspect the problem is water in the fuel...
After posting about the tractor earlier today, I decided to check out the tractor. Yesterday I put a battery charger on the battery so the battery was fully charged. I thought I'd try to start the tractor with a fully charged battery now that the water was hopefully cleaned out of the fuel. At first the tractor didn't attempt to fire. Then it sputtered. Then it sputtered some more. Then it sputtered some more, each time sputtering longer. I kept the key turned and eventually the tractor started running on its own!
Yesterday I was pleased with the outcome of some of our porch work but the whole time I felt the weight of the tractor problem so I couldn't fully enjoy my porch work. The weight is lifted now.
Happy! Happy! Happy!
I let the tractor run a while then parked it. I still need a new fuel filter and will order one.
The whole water issue has been a learning experience. I've learned some maintenance pieces that are good to know. Finding out about how to drain the fuel tank was a valueable piece of info. After we bought the tractor, we ordered an owner's manuel and a tech manuel for it. I've been looking through the manuels and found the suggestion to drain the tank and how to do it. A lot of the stuff on the tractor is hard to see which makes it tough to follow hoses to figure out where they go. The manuels help a lot, especially for someone like me who doesn't know what he's doing.
Obed - Problems with water is a god reason to have a shelter for your tractor.
I keep mine in a garage I added to the side of the main garage. It houses my two tractors and snow blower and push mower. My hand tools, ladders, weedwackers and chain saws are all in this garage. Another garage houses extra implements not in use during different seasons.
This garage gives me the opportunity to keep trickle chargers on batteries, storage shelfs for oil and additives for all the equipment.
Here I go again spending your money on suggestions to improve your quality of life.
PAGUY,
Our basement 'garage' is slated to house the tractor. We haven't added the basement garage door yet; it is temporarilly framed in.
Obed -
Sooo....what are you putting in the garage then?? Wife's car, and the JD? Will you're dually fit?
Frank,
We have 2 cars, the dually, and the JD tractor but only 3 garage bays. We'll park my wife's car and my car in the main floor garage. The dually will fit in the main floor garage but we probably won't park it in the garage. One garage door is 10 feet wide, specifically so we could put the dually in the garage if desired. The basement garage door opening is currently filled in with a framed wall. My intention is to park the JD in the basement garage once we put up a garage door in the basement.
Obed
Also a full tank is better for messing with the filters as there is more weight on the fuel to let gravity force the air out of the bowl.
clemsonfor, that make's a lot of sense. My fuel tank is not very full; that may have been the reason the bowl did not fill up buy itself. Great suggestion.
Where are you buying you fuel? Or is this drian and water pudding you think your problem, you sure have a lot of problem with water in the fuel? Either park it in your garage or just put a board or something over that fuel cap.
I suspect the problem is the puddling of water around the fuel cap when the drain line was clogged with debris. The drain line has been clogged for a long time. I tried a few months ago to run a wire down the hose to clean it out but was unsuccessful. Yesterday was the first time I thought about blowing the line out with the air compressor. The air compressor is still a relatively new purchase so using it in this way was not in forefront of my mind.
Obed
It would be eiser to use a liquid spray like you use in your house for bugs or if you have some for your garden.
clemsonfor,
Yes, spraying liquid wasp killer would be easier. However, we are planning on staining the boards up high below the porch roof line. We didn't want the residue from liquid poison getting on the wood prior to staining them. We don't want to put something on the wood that will hinder the stain from adhering to the wood. Plus, we've had great success with the fire ant poison killing yellow jacket nests so thought we'd try it on the carpenter bees.
Obed
Then I cleaned out the gutters, knocked down 20 wasp nests out of our attic.
You might look into a finer mesh to keep the wasps out? I live in blind happiness in a mobile home with no attic access. I could have 40 nest in my attic.:cool:
Kyle,
One of my regrets regarding building our house was how the ridge vents at the top of our roof were installed. Wasps can get through/around the ridge vents and get into the attic. If I could do it over I would have the installers put down screen material along the ridge of the roof before installing the ridge vents. It would be very easy to do and would help to keep wasps and hornets out of the attic. But there were so many things going on at that time, that's a detail I missed. Now I'll kick myself every spring and summer while I go around knocking down wasp nests. As long as I don't let the nests get big, it's not that hard to do. I spent about 45 minutes yesterday looking for nests and knocking them down. I assume springtime will be the worst time while the queens are looking for a place to make a home. I hope that new nests will taper off as the summer progresses. I'm also hoping that the queens will give up trying to build in our attic and go somewhere else when their nests keep getting knocked down.
Obed
I went up into the attic to inspect for wasps. I only found two wasp nests and subsequently knocked them down. Two nests this spring versus twenty nests last spring was quite an improvement. I can live with only knocking down two. Maybe the queens gave up and went elsewhere?
My wife harvested some oregano out of her herb garden that is beside the house. Often, when she is cooking, she will walk out to the herb garden a break off a twig or two of something to use a seasoning for the dish.
The porch handrails will be 2x6s sitting on top of a 2x4 for support.
We got the first green beans out of the garden. Green beans and squash are staples in our house. Unfortunately, the squash plants aren't being polinated so the plants haven't started growing any squash. We hope that situation changes.
In the picture you are seeing the stinger end of a dead carpenter bee sticking out of the bee hole in the porch below the roof. The fire ant poison must have killed the bee. My wife also picked up a badminton racquet from the thrift store. I haven't been able to kill any bees yet with it. Most of the bees are dead. However, we have at least one bee still living. No poison got put it its hole. I saw it flying around yesterday but didn't get a good chance to swat it with the badminton racquet.
My wife put down leaf mulch at a couple places around the house. The spot in the front of the house will eventual get some shrubs planted in it. My wife hasn't figured out what shrubs she wants.
The spot behind the basement is a place we don't want to mow. The area beside the HVAC unit at the end of the retaining wall was hard to get to with the riding mower so my wife hoed away the grass and put down the leaf mulch.
1202 (A58374)
1202 (A58374)
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A55973)
2015 Freightliner...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
