ASV RC100- low flow issues
/ ASV RC100- low flow issues #1
479Scaper
Fayetteville Arkansas
ASV 4500HD, ASV RC100
Recently removed the skid plates and cleaned the underside of the machine, did not use a power washer. Now I only have low flow in one direction, has anyone repaired this problem before? Also the low flow continuous switch lights up, but does not engage. Appreciate any feed back...:confused:
An update on my machine, I sent some pm's to other members of the TBN and they were very helpful in starting me in the right direction. I also called the service tech at Terex and they were very helpful. I downloaded a service manual and lifted the cab, removed the left and right controls and then removed the floor, all to expose the solenoid block. We had checked all the fuses and relays and everything was in order so I had to figure I had a bad solenoid but I found an even easier fix, some sort of small rodent had chewed completely thru the wire to the solenoid that had stopped working. Anyway now that I traced the wiring of this machine it will be much easier to diagnose in the future. Pretty straight forward layout .
Concrete Mixer (A66408)
Concrete Mixer...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
Frontier GM1060E (A64126)
Frontier GM1060E...
2018 F-150 4WD (A63688)
2018 F-150 4WD...
2015 PETERBILT 579 TRI/A DUMP TRUCK (A59914)
2015 PETERBILT 579...
