ASV BROKE!!!
Status
Not open for further replies.
/ ASV BROKE!!!
I can't just change the bearings because the bearing failure caused the idlers to move forward & chewed up the rubber idler wheels, so all is going to need replacing!
Thanks for the feedback!!
/ ASV BROKE!!! #12
Well I got a quote on the idler assembly today. OUCH!! $954.00 in stock WOW I never thought it would be that much. I am just gonna fix the idler assembly & bolt on some new drive lugs & keeper goin. Gonna have to save some more money for the rest of them when the time comes.
Does anyone know if I can get them cheaper anywhere else?
:confused2:
I paid around $100 dollars less by using my end plates and bolts. Once I had one go out two more went out soon after. That machine broke my ***.
/ ASV BROKE!!!
Well Ax I sent the wife to get the parts & to my understanding they just had the whole assembly anyway thats what she came home with. Now I went to put it on & the dang starter went out I guess. There is sparks comming from the inside of the starter when the key is turned, so now something else to fix before the main item!!! URGH!!!!:confused:
/ ASV BROKE!!! #15
Where did you get the price from? I remember the one's from Pucket being the cheapest. Yep those bearings are a very common failure down here on the ASVs
/ ASV BROKE!!!
I dunno about Pucket but I bought from Vermeer in Jackson! Probably should've call them & checked!!
How you been Dirty haven't seen you on here in a while?
/ ASV BROKE!!! #17
Sorry to hear about your luck man. I have been busy with my 9-5 and just grinding stumps on the side. I need to meet up with you in Hat one day next week and swap out some cards. I may even have a few leads for ya.
/ ASV BROKE!!!
Well tell you the truth I been working in the Oil Field since January for my old Boss. It is 9-5 plus 24-7 sometimes. So not so much time mulching. I need to do some jobs but the main one comes first. Know what I mean!!
/ ASV BROKE!!! #19
I'm not sure, but these guys may be able to redo that too (custom bonding). Sometimes you gotta be creative to be frugal :)
Clutch and Friction Service - Brake Linings and Clutches for all types equipment, bonding of Fiat Allis, John Deer, Hough and Overhead Crane Brake Shoes
/ ASV BROKE!!! #20
You did the right thing buying the new one. When they go out they are shot. I know what you are going through and I hope the others stay strong. Mine had the same amount of hours when they started failing. Save your bolts,nuts and end plates.
Status
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A61567)
2006 John Deere...
2020 BOBCAT E42 MINI EXCAVATOR (A60736)
2020 BOBCAT E42...
John Deere Hopper Assembly Kit (A60463)
John Deere Hopper...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 CAT 950K WHEEL LOADER (A60736)
2013 CAT 950K...
