assemble pto drive shaft
   / assemble pto drive shaft #1
geoffleach
mountain ranch, ca
Antonio Carraro TRH 9800, TTR 4400
This concerns a PTO drive shaft that has come apart. The shaft itself, not its PTO connection. The shaft connection is splined. The tractor side has a section where there are no splines - width of two or three splines. I would expect to find a matching section on the implement side, but no dice. The tractor side can be fitted to the implement side, but only slips in a half inch or so.
So, what am I missing? (FWIW, the implement is a Rears 750 mower)
   / assemble pto drive shaft #2
I always hated those fine splined ones, my Uncle had a tiller with a shaft like that, we found it easier to lay a straight edge on the shaft side yokes to be sure it was phased, then it can only go in one of two places 180 degrees apart
   / assemble pto drive shaft #3
Look real close at the male shaft , 1/2 " in where it stops there will be a tiny dot of weld between two of the splines. That has to line up with where the splines are missing on the female side. B
   / assemble pto drive shaft #4
Had one PTO shaft that had 2 splines that were "pinched" together in one spot. Those slipped into the female part where the gap was.
   / assemble pto drive shaft #5
Ditto 2 splines pinched together on male end is the way my splined shaft is. They can be a pain to get lined up.
Bush Hog 3126R 10' Pull Rotary Mower (A50774)
Bush Hog 3126R 10'...
PT 8' Offset Disc (A50121)
PT 8' Offset Disc...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2020 GMC 2500 HD (A50120)
2020 GMC 2500 HD...
