Buying Advice Artillian Pallet Fork Question
/ Artillian Pallet Fork Question #1
sjhulsmn
St. Joseph, MN
JD 3720cab w/300CX loader, JD 955 w/70A loader,, JD737 zero-turn
For those of you that have Artillian pallet forks, do you like them or do you wish you had another brand of pallet fork? Also, for those of you that are familiar with Artillian pallet fork products, what is the advantage of the Cascade fork vs. the standard fork? Also, what is the difference between standard and full taper forks? According to the Artillian web site, the Cascade forks are heavier then the standard forks and are made in the USA. I've have a JD 1070 with 440 loader that I'm thinking of getting a set of forks for. One of my main uses for forks will be removing rocks from my field. Some of these rocks weigh between 300 to maybe 700 pounds. Any input is appreciated.
/ Artillian Pallet Fork Question #2
Artillian makes a great product. They are lighter than any of the comparable forks and just as strong. The benefit of them being light is less dead weight in the forks, so more lifting capacity. There's also a ton of great 'add-ons' for the Artillian that others don't offer. I don't have them myself, but those who do seem quite satisfied, my tractors are just to big for them.
/ Artillian Pallet Fork Question #3
I'm very satisfied with the standard tines. I wouldn't buy the Cascade tines personally.
However...if you plan on digging rocks why not get a pair of his 24" tines, that's why he's selling them. That being the case, the 24's don't come from Cascade so you don't have to make a decision.
/ Artillian Pallet Fork Question #4
I purchased Artillian forks earlier this year and I am very pleased with them. I ordered the 42"x4" Cascade Fork Tine, Pallet Fork Frame Removable Backrest, and the JDQA Pallet Fork Frame. I have absolutely no regrets and I use these forks on a regular basis.
/ Artillian Pallet Fork Question #5
Chris's (Artillian) forks are amazing. They are well designed by someone who knows exactly what he's doing. This means that he doesn't have any more metal (ie weight) than he needs and this means you keep as much lifting capacity as possible. His design experience (backed up by analysis you can see on the site) also means that you can have confidence they won't fail. He's honest and cares about his customers like a small business man should. Great product, great company. On a similar side note, his glare shields are a life saver.
/ Artillian Pallet Fork Question #6
Very happy with my Artillian forks. Less dead weight. If I ever have the need to purchase more items, I would buy them from Chris before I go looking else where.
/ Artillian Pallet Fork Question #7
I purchased the frame, Cascade standard taper forks and the 24" forks from artillian, and am very happy. My understanding is that the standard taper is slightly heavier than the full taper. The widths are different, my cascade standard taper forks are 3" wide, the full taper forks are 4" wide.
Very highly recommended: Well engineered and thought out product, and Chris is fantastic to deal with!!!
Thanks everyone for your input - all very helpful!
/ Artillian Pallet Fork Question #9
+1 on everything that has been said.
I bought mine about a year ago, and the design has changed a tiny but since then making them even better now.
/ Artillian Pallet Fork Question #10
I too have had an Artillian Pallet Fork for a year and a half and am completely satisfied with it. I would absolutely buy another one.
/ Artillian Pallet Fork Question #11
I bought a set of these forks a few weeks ago. So far, no issues. Quick hitch matched up perfectly and the frame seems to be very well built. Chris was great to work with.
/ Artillian Pallet Fork Question #12
Agree that these Forks are awesome. I only got the 24" forks and am thinking about adding the 43 or 36 inch as well. The 24" are PERFECT to move boulders. Anything longer may just get in the way and the 24 are fine for anything my 1025r can lift. Chris was awesome to work / talk with as well. Actually bought 2 sets now. One set for my 1025r and another for My Uncles 4005 (could have shared but the machines are 400 miles away from each other)
/ Artillian Pallet Fork Question #13
When I purchased Artillian forks recently, I opted for the 36" length, hoping they would be a decent compromise. So far, so good . . . but time will tell. :)
/ Artillian Pallet Fork Question #14
I was thinking of ordering the artillian forks but was wondering if I could save a few bucks by just ordering the frame and getting some used forks locally off of CL. Would they fit? Here's a pic of some available locally, if the attachment works that is. Forks.JPG
2006 UTILITY TRAILER MFG. CO. 48X102 SPREAD AXLE COMBO FLATBED (A67714)
2006 UTILITY...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 INTERNATIONAL...
2014 TEXAS PRIDE GOOSENECK TRAILER (A67714)
2014 TEXAS PRIDE...
2014 Chevrolet Impala Sedan (A66738)
2014 Chevrolet...
PALLET OF MEC 8000 PUMP AND V8 ENGINE BLOCK (A68842)
PALLET OF MEC 8000...
