Articulating Hitch
/ Articulating Hitch #1
nwngunner
Maquoketa, Iowa
806Farmall 1650Oliver
Here a few weeks ago, i was out mowing with my atv and my rough cut mower. Now the issue i have, the mower came with a really lite weight 3/8 straight pin hitch. My atv has a 2inch style receiver so i was just pulling the mower with a draw bar.
Now if i am mowing on the flats and turning only left and right its fine, how ever when i am in the hills and the brush i am turning on all three axis. So now i have to rebuild the toung on my mower, so i need to come up with some sort of articulating hitch. Need something that will move on all three axis. Perfer something that has like a poly bushing to help eat up the bumps going down hill. Any one ever build one or know where to look for one?
I have a rough cut and a finish mower that i would like for the hitch to work on. Also might want to convert one to hook a ball trailer to for when i am out fencing i can take my small mower trailer with me
/ Articulating Hitch #2
Use a regular trailer ball and coupler, or you could use a lift arm repair end.
SpeeCo lift arm repair end
For lighter duty, use a ball joint in whatever size you want.
For a cheap light duty hitch, use an old automotive tie rod end.
Bruce
/ Articulating Hitch #3
I have seen them for five dollars at a local farm supply store. A great idea and alot of machine work for the money.
/ Articulating Hitch #4
how much twist are you dealing with?
I have seen a pipe and a shaft that could rotate and then a clevis type hitch on that, could be made on either end, ATV or mower end,
the Pintle hitch on my truck will rotate completely around, http://shufti.files.wordpress.com/2012/01/img_5168.jpg or Pintle hitch shooftie
rotating receiver hitch extension,
[ame=http://www.amazon.com/HitchMate-5990-RotoHitch-Rotating-Extension/dp/B006VML35M]Amazon.com: HitchMate 5990 Black RotoHitch Rotating Hitch Extension: Automotive[/ame]
If you need a compleat articulation some thing like a U joint on a rotaing attachment, gives you up and down right and left and 360 rotoation,
I would think some thing like the pintel hitch would do the same,
/ Articulating Hitch #5
Can you build one similar to what I did on my snowmobile gear trailer? Long bolt with springs on both sides to absorb bumps and shock. It will swivel 360* with no restrictions.
I like that, only thing is i would still be limited on the up and down "folding" type motion. I am going to look into a ball joint in town here in a bit and see what i can figure out.
/ Articulating Hitch #8
a standard ball hitch gives about 30deg rotation in vertical axis which may be enough for your little wagon, er mower.
/ Articulating Hitch #10
A "pintel" hitch (aka a military style hitch).
The quad has a 2inch receiver hitch already. I pull my 9foot mower trailer with it all the time. It was more of an issue for my pull behind rough cut and trail mowers. I found a hime joint in town that is going to work. I am just going to make my own receiver hitch.
/ Articulating Hitch #13
Could you just cut the draw bar in half and put a heavy hinge in to allow it to pivot up and down? Left to right pivot is already accomodated by the straight pin. Basically cut where the line is and bolt or weld on the hinge.
Quick and easy and would work with your existing 2" receiver on your atv. Since you have the drawbar already, if you make the hinge out of some 3/4 or 1" tube with a bolt or pin through it, it could be free.
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
2013 FORD F-250 SUPER DUTY (A65643)
2013 FORD F-250...
2009 Kubota M108S (A64119)
2009 Kubota M108S...
