Are there enough used CUTs out there?
   / Are there enough used CUTs out there? #81
there are plenty of used cuts around people just dont have the cash to get or muster a loan outside of the special loans on new dealer equipment - the other issue is people want a specific unit and are not looking for anything but that so they dont consider anything else that is available - theres plenty of them around especially with the access to the internet
When I was shopping for a 30-35 HP tractor I found just one used that I was interested in... a clean 10 year old Kubota with 1000 hours on it. Everything else had bukos hours on it, or was priced at new. I did have to take out a loan but was pre approved at the CU at 2 1/4% plus had a good down payment.
My fallback was a new geared 3301 for 20.5K, but I ended up with 2 YO 3301 HST for about 3K less. It also came with a canopy, tire chains and grapple setup.
   / Are there enough used CUTs out there? #82
Nards,is there a name of a dealer that you can give me in Canada that gives that good of deals on trucks?
   / Are there enough used CUTs out there? #83
its not canadian its American. They import them. Try FX Caprara ford, doge, chevy.
   / Are there enough used CUTs out there? #85
Thank You!
   / Are there enough used CUTs out there? #86
Back when we were looking for our first tractor, we figured it would have to be a used 20 to 40 hp tractor - either compact or utility.
We wanted a loader & a 3pt for sure. Hopefully power steering & 4wd.
They all seemed to fall into the following categories:
1. New
2. Used, not needing much or any maintenance
3. Used, could use lots of maintenance & even some repairs but with all the important systems working - i.e leaks, seals, sloppy steering, flat tires, won't charge.
4. Used, definitely needing mechanical repairs on a major system to get it to work, but able to be repaired. i.e. no hydraulics, front axle/driveshaft broken
5. Junk
To my surprise it was easy to tell which slot that a particular tractor fit into. I think cars & trucks are more difficult.
It didn't take long to figure out that some machines - particularly some older ones - were designed to be repaired & others were not.
Repairability and parts availability made some old machines move up into repairable categories 3 & 4 while newer tractors with the same problem did not.
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2012 PETERBILT 386 (A50854)
2012 PETERBILT 386...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2008 MAGNUM PRODUCTS LIGHT TOWER (A50854)
2008 MAGNUM...
