Are diesel conditioners needed for new
   / Are diesel conditioners needed for new #31
I've used Howes in my tractor with mechanical injected Kukje engine for anti gel properties after watching project farms test of products what worked. In my higher tech common rail engines I use HotShot Secret anti gel and cetane booster in the winter.
I just ordered some of the HotShot Secret Anti Gel tonight. It gets great reviews and a lot of people in northern climates are using it. I use what the Northern folks use for Anti-gel.
   / Are diesel conditioners needed for new #32
I've used Amsoil's, diesel all in one, in my tractor, rtv, and truck since new. They claim outstanding detergency, improved lubricity, better cold flow, and higher octane.
Yep I put cetane but the auto correct demon changed it:LOL:
   / Are diesel conditioners needed for new #34
It is very good. Thats what I use.
   / Are diesel conditioners needed for new #35
I have been using the PS white bottle since 2008 for my truck
every fill up gets some winter or summer so always ready.
Never had a gel up so far but have seen others. Someone in
town had a 18 wheeler tractor and it was cold enough to get his
fuel and they spent over 3 hours pulling it back and forth on main
drag and they could only get the exhaust stack to puff white smoke
willy
   / Are diesel conditioners needed for new #36
Here in southern NH, I just run plain old diesel in my Bobcat CT230. The most time the fuel will sit in the tractor is maybe a month if I'm not using it much. Longest I've had any fuel sit in the plastic jerry cans in the garage is 4 months (2, 5 gallon cans) Never had a problem.
   / Are diesel conditioners needed for new #37
I use atf in all my diesels from my pickup to my 1956 820 John Deere. They love me for it.. I add a quart to 40 gallons of fuel for my older tractors. My2000 F-250 gets 3 to 4 oz per fill-up. I have no way to prove anything except none of them has ever had fuel system work done on them. I noticed as I was balingthat the primary pump on the 730 is leaking so a reseal will be the first fuel system work it has ever had.
   / Are diesel conditioners needed for new #38
I also run white power service in the winter for gelling and carry power service 911 for the odd chance of bad fuel. This has worked quite well for me.
   / Are diesel conditioners needed for new #39
Bio-diesel is great stuff if you burn it out, like over the road truckers do. But don't let it sit in your tank without dosing it with a biocide of some kind. (Power Service Silver year around here. I don't operate when/where it's cold.)
   / Are diesel conditioners needed for new #40
Allow me to add to the discussion.
I use either Stanadyne performance formula Or Alliant Power Ultra Guard
Both these were recommended by the diesel pump shop I use and made for and recommended by the manufacturer of diesel pumps and injectors.
Figure they ought to know what is good to use.
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
Adams 6 Ton Fertilizer Spreader (A56435)
Adams 6 Ton...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2020 Topcat 48" Hydraulic Articulating Skid Steer Cutter, S/N BORC20120101, Asset# 69 (A59076)
2020 Topcat 48"...
2016 Ford Taurus Sedan (A56859)
2016 Ford Taurus...
2014 Bolens 11A-020W765 20in Push Mower (A55973)
2014 Bolens...
