Anyway to adjust bucket level indicator?
   / Anyway to adjust bucket level indicator? #22
My bucket indicator is a tube and rod. I had the same issues you have, and did not want to cut the rod. I put a piece of 3/4" pex with a notch cut out on the tube. With the bucket on the ground and level adjust the pex so the rod is even with the end. The notch in the pex is so you can see how far below level the rod/bucket tip is.
I did this the other day with a scrap of ptex. Excellent!!!
   / Anyway to adjust bucket level indicator? #23
I used tape on my last tractor. I clamped a bit of Romex wire to socket where the leveler comes out. I can bend it adjust for different bucket angles if necessary.
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
27033 (A55852)
27033 (A55852)
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
2012 FREIGHTLINER 4300 DURASTAR (INOPERABLE) (A55745)
2012 FREIGHTLINER...
