Anything but a hydro...why?
   / Anything but a hydro...why? #42
I have never driven a tractor with a Hst tranny so I can't speak to the pros and cons. I bought a lease return tractor that was big enough for my needs, at a cost I could afford and it had shuttle shift. Works fine. It is paid for. If there is a next tractor, I will have to make a choice. If Hst is anything like an automatic tranny, a bit of a bore, I will go running back to the shuttle shift.
But when my neighbor fires up his Kubota with Hst I always know because of the nasty whining noise that I can hear at 500 feet. I assume that ear protection is a good idea. Do they all whine like that?
It seems like the smaller and newer they are the worse the whine. I noticed the neighbor had a bx for a bit and it was noisey, and my L3400HST whined more before it broke in. but not as much as that BX and the whine now is barely noticeable at all over the purr of the diesel. And running a hydro is nothing like running an automatic tranny in a car or truck.. much better in my opinion.. If fact I have gotten in my truck and pushed down on the floor mat with my heel to go in reverse, and wondered why the stupid thing did not move
James K0UA
   / Anything but a hydro...why? #43
Daedong CUTs (Kioti/Bobcat/McCormick/Landini) do have a clutch pedal on the HST model. You can't start it unless it's pushed in and they have a lock to lock it open if it's being stored, other than that, it's not used. I could be completely wrong, but I think some Kubotas have them too.
You can only shift on the move with the Kubota HST+ (I believe JD has a version called eHydro). Daedong uses the older HST type transmission and you have to stop to change ranges.
what's hst plus
Ken, I don't own an HST Kioti, but I'm not sure you have this right. The DK series with electric over hydraulic PTO switches don't have clutch pedals because the switch is used to control PTO. And on the CK HSTs, I think the clutch still disengages the PTO (live PTO), but serves no purpose for the tranny.
   / Anything but a hydro...why? #44
It's call HST+ at Kubota, and yes, it is expensive. JD has a similar version, can't remember what they call it.
Sorry, didn't see nybirdman beat me to it.
Yes, Kubota and JD have a dual speed HST. New Holland was the first to have something similar. I have that on my New Holland, but when I need to change ranges of the geared portion, I still have to stop and move a lever. Now I could be wrong, but I believe to move into a higher/lower geared range, both Kubota and JD require a manual shift. The way the dual speeds on HSTs are done is by changing the angle of the swashplate in the motor side of the HST. Your foot pedal changes the swashplate on the hydraulic pump, but by changing the swashplate angle on the motor, there is a "dual-speed" effect.
   / Anything but a hydro...why? #45
The clutch on my Kubota is needed to start the engine (safety switch) but it also disegages the hydro as well as the PTO.. It also allows you to soft start up the PTO by throttleing down and feathering the clutch as the load on the PTO ramps up. Also an easy safety "switch" when your rotary cutter finds a big ole rock. It is easier to stomp that clutch, which you have been trained to do for years driving gear tractors than hunt around on the dash for the dang electrical switch that disengages the PTO.. So I like my clutch.. but for 99 percent of the time.. it is as useless as those appendages on a boar hog:laughing:
James K0UA
   / Anything but a hydro...why? #46
Jim I believe the HST+ models still have a 3 range non synchromesh transmission, and work just like you described. In essence giving 6 forward ranges 3 hard shifted X the 2 soft.
James K0UA
   / Anything but a hydro...why? #47
Check out the link in my earlier post to see how the "new" HST (HST+/eHydro) works, it's a little different now. Most "old" HST (as you describe above) is now 3 range, although I think I preferred the 2 range of my JD 955.
   / Anything but a hydro...why? #48
Yes, I stand corrected, the DK line doesn't have a clutch, I was purely speaking of the CK line. The clutch on the CK line cuts all hydraulic power, both the PTO and HST. Writing this, I'm now curious about my power steering, I think it still has hydraulic power with the clutch in, you just gave me a reason to fire it up, thanks.
   / Anything but a hydro...why? #49
James K0UA
Agreed, my GL, unlike the L has an independent PTO, so I can "feather" the PTO with the PTO lever, but of course the newer GL have replaced the lever with a switch. All the tractors I use have independent PTO and with the exception of the 5030 pushing the clutch pedal has no effect, so doing so on the Kubota is not instinctive, I just hit the lever and raise the 3PH lever if I hit something.
   / Anything but a hydro...why? #50
I like the HST, my newest HST "trick" is for hooking up the hay spear on the the FEL. I can inch the tractor forward or back and run the loader standing on the right side of the tractor, even with the parking brake on. Probably not recommended by the safety police but that dang spear is a bit narrow and light so I can end up pushing it around for a while unless I get off and manually get it close and then hook up. I just watch that I don't slip and grab a hst pedal on the way down.
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2013 Ford E-150 Passenger Van (A59230)
2013 Ford E-150...
2860 (A56857)
2860 (A56857)
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
