Anyone using costco diesel fuel?
/ Anyone using costco diesel fuel? #1
Rob 80
WVA
B2650
Just wondering your thoughts on there diesel fuel? I usually buy mine at BP but the new costco sells it.
/ Anyone using costco diesel fuel? #2
I have gotten a few 5 gallon cans of it, but likely won't since it has bio diesel in it. I don't have high usage and don't need issues that I have heard of with bio diesel. I have not experienced them yet myself, but have no reason to take the risk.. if I had higher usage, I wouldn't worry about it. one of the daughters offered to get me off road diesel whenever I wanted..
I'm not familiar with bio diesel but i think BP calls there's off road, i don't use it a lot so i take it bio diesel can't sit around long?
How do you know costco uses bio diesel? I see nothing about it on there website and a lot of these gas stations don't really tell you what's in it and i bet if i asked the store clerk i'd get a funny look!
/ Anyone using costco diesel fuel? #4
Bio diesel is refined vegetable oil rather than refined petroleum. It's a better solvent than regular diesel in many cases & can cause issues with seals & rubber. It also has more moisture issues than normal diesel. But it also lubricates better than normal diesel by a decent bit.
It's pretty common to have small percentages of bio diesel mixed into regular diesel. Up to 10% or so, at least for summer blends. I think it gells a little easier than normal diesel.
Off-road diesel (or home heating oil, same thing) is diesel with red dye in it to indicate you havent paid road taxes. It might be less likely to have bio mixed in due to the falling temps & the fact it's also heating oil, but that's not a guarantee.
/ Anyone using costco diesel fuel? #5
My Toolcat manual says not to use Bio diesel.
/ Anyone using costco diesel fuel? #7
Around here all the Diesel fuel comes from the same California refinery and goes into the same tank farm tank. Not sure when or if any different additives are blended in by the different companies using the same fuel.
/ Anyone using costco diesel fuel? #9
Costco has a web page with a bunch of specs for their fuel. It's more than I can find from local stations.
California diesel has high cetane rating for emissions reasons, but that also increases performance. It probably costs more than lower cetane fuel but less than adding additives to raise cetane.
Since they have high turnover the diesel from there should be fresh and not likely to have water in it.
/ Anyone using costco diesel fuel? #10
I use Costco's diesel in my truck when I'm in the vicinity and need at least one of my tanks (18g+19g, typically fill 15-17) filled.
I've used it for a few years, and haven't had any cause for concern.
I don't recall a biodiesel note on the pumps I've used (CA - most often Roseville and a couple times in south San Jose, OR - a couple times in Medford & Eugene if I recall).
/ Anyone using costco diesel fuel? #11
Costco does not sell diesel here.
I went to costco it say's may contain up to 5% biodiesel. Also went to BP it just says Ultra low sulfur diesel fuel 15 ppm sulfur max. for use in all highway diesel vecicles and engines.
/ Anyone using costco diesel fuel? #13
I fill up at Costco in Oregon when up I'm there. .80 per gallon cheaper than where I live in California. Never had an issue. For the tractor I use red dyed farm diesel from fuel supplier, which is another 20 or so cents cheaper.
/ Anyone using costco diesel fuel? #14
From the horse's mouth;
Q: Does Kirkland Signature™ Diesel contain biodiesel?
A: Kirkland Signature™ Diesel only contains biodiesel where required by law. However, up to 5% biodiesel may be found in any US diesel fuel without it being marked on the retail dispenser. This rule allows biodiesel and regular petroleum diesel to be transported in the same pipelines and tankers.
Gasoline Question and Answer | Costco
/ Anyone using costco diesel fuel? #15
The Kalamazoo Costco also does not sell diesel. I don't know why not, and I wish they did.
/ Anyone using costco diesel fuel? #16
Vegetable oil is one source of biodiesel. It's also made from animal fat and renderings. I'm familiar with biodiesel made from pork products. I assume it can be made from beef byproducts also.
2013 Ford E-150 Passenger Van (A59230)
2013 Ford E-150...
UNUSED FUTURE FT-GB200-79"X71 1/2"-1" STEEL PLATE (A60432)
UNUSED FUTURE...
case 370 glass door never installed (A61306)
case 370 glass...
UNUSED 7" MINI EXCAVATOR TOOTHBED BUCKET (A60432)
UNUSED 7" MINI...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
