Anyone think this is accurate?
   / Anyone think this is accurate? #21
I own both types as well. The heavy duty bucket is indeed more robust. The only problem is, it weighs more, which lessens the lifting capacity of the FEL.
Not appreciably more, maybe 100 pounds my case, 100 pounds is trivial. I have almost 3K lift capacity on both mine.
   / Anyone think this is accurate? #22
I see that I'd probably need to bring my tractor to actually get it home. At least I could check the clearance. I'm seriously considering it.
Or make a cardboard cutout of ballast's footprint, including the lower pins, to see if your lower links will splay enough to hook it up, and if the front ballast corners clear your lower links. Might save you a trip.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56435)
2023 Top Air ATV...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
ALLISON TRANSMISSION (A55745)
ALLISON...
SHOPBUILT T/A BUMPER PULL TRAILER (A52708)
SHOPBUILT T/A...
