Anyone make a ratcheting wrench for a cat 1 top link?
   / Anyone make a ratcheting wrench for a cat 1 top link? #61
Chains are ok if you have something like a mower you want to follow the contour of the ground, but if you want something like a rear blade kept at a certain angle, you need a top link ...
   / Anyone make a ratcheting wrench for a cat 1 top link? #62
Dual remotes for my Kubota B2601 cost over $1000, so there is that....
The assumption is that there’s at least one set of remotes available. Adding them when none are installed can be very expensive.
   / Anyone make a ratcheting wrench for a cat 1 top link? #63
   / Anyone make a ratcheting wrench for a cat 1 top link? #64
I have a Massey GC1715 compact tractor. I would like to make it easier to adjust my top link. I can’t afford to add rear hydraulics and I’m getting too old to keep struggling to adjust it with my hand. The link doesn’t have a pin drilled through it to spin the link, it just has a u shaped hole on the side of it. The OD of the movable link is approximately 1-1/4”. I was thinking of getting a ratcheting gear wrench to put over the link or even a manual ratcheting pipe thread head wrench but not sure how to attach it, that is if I can find one to fit.
It would be nice if I could take the handle off while not in use.
I’m worried about harming the ratchet if I weld it to the link. I don’t know, maybe it would be ok?
I did sorta find something on line but I didn’t want to drill a hole through my link.
Has anyone done this before or have a better or easier idea?
Like this but modified to work with you Link.
   / Anyone make a ratcheting wrench for a cat 1 top link? #65
Are those barbell weights ?
Yup, I stuck a piece of 3/4" black iron pipe through the backhoe frame, and can put on 275 Lbs ... Mostly for when I'm using my rear blade, as once I drop that on the ground, not much weight on the back of the tractor ...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
FRONTIER 5' BOX BLADE (A52708)
FRONTIER 5' BOX...
2006 APPA TL (A55787)
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
3410 (A47477)
3410 (A47477)
2020 4-Fuel 800 Gallon Fuel Tank, Model 4F-838, S/N 4F-838811/20, Nominal Capacity, 838 Gallon/3172 (A59076)
2020 4-Fuel 800...
