Anyone make a ratcheting wrench for a cat 1 top link?
   / Anyone make a ratcheting wrench for a cat 1 top link? #52
He said he can't afford to add rear hydraulics.... this is the cylinder. Now find the rear hydraulics for his tractor.
Just run the lines to the rear.
   / Anyone make a ratcheting wrench for a cat 1 top link? #54
At $166 it’s very cheap. The ratcheting solution that the person was suggesting would cost at least half that, probably more. So getting hydraulic link for an extra $80, especially when you’re not getting younger is a no brainer.
Dual remotes for my Kubota B2601 cost over $1000, so there is that....
   / Anyone make a ratcheting wrench for a cat 1 top link? #55
How about a cordless top link adjuster...
   / Anyone make a ratcheting wrench for a cat 1 top link? #56
I carry a 14" pipe wrench in my tool box to adjust the top link.
It has a hole through the center, with a 3/8" rod, but the rod is always in the way when unused.
   / Anyone make a ratcheting wrench for a cat 1 top link? #57
   / Anyone make a ratcheting wrench for a cat 1 top link? #58
Converted mine over to hydraulic. Best thing I did for my tractor!
Agreed.
Intial cost felt expensive but now that I have it, it's worth every penny.
   / Anyone make a ratcheting wrench for a cat 1 top link? #60
I've seen pictures of people using chains.
I have several top links and keep one with each piece of equipment. no need to adjust every time you swap something.
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
HAMM HD14i SMOOTH DBL DRUM ROLLER (A52707)
HAMM HD14i SMOOTH...
2014 Cadillac ATS Sedan (A55853)
2014 Cadillac ATS...
