Anyone make a ratcheting wrench for a cat 1 top link?
   / Anyone make a ratcheting wrench for a cat 1 top link? #1
Jg1
Member
Cub Cadet 7195
I have a Massey GC1715 compact tractor. I would like to make it easier to adjust my top link. I can’t afford to add rear hydraulics and I’m getting too old to keep struggling to adjust it with my hand. The link doesn’t have a pin drilled through it to spin the link, it just has a u shaped hole on the side of it. The OD of the movable link is approximately 1-1/4”. I was thinking of getting a ratcheting gear wrench to put over the link or even a manual ratcheting pipe thread head wrench but not sure how to attach it, that is if I can find one to fit.
It would be nice if I could take the handle off while not in use.
I’m worried about harming the ratchet if I weld it to the link. I don’t know, maybe it would be ok?
I did sorta find something on line but I didn’t want to drill a hole through my link.
Has anyone done this before or have a better or easier idea?
   / Anyone make a ratcheting wrench for a cat 1 top link? #2
Why not just go buy a new top link and forget about modifying yours? Harbor Freight sells them, as does TSC, Rural King and every tractor supply store.
   / Anyone make a ratcheting wrench for a cat 1 top link? #3
Like a load binder with spherical bearings at both ends?
   / Anyone make a ratcheting wrench for a cat 1 top link? #5
I’ll have to look into the chain binder to see if I can find one with a close enough length as the existing top link. Also the thread size for my ball joints.
My Massey Ferguson does not have a power beyond port for the hydraulics.
   / Anyone make a ratcheting wrench for a cat 1 top link? #8
I also found this but I couldn’t find one with the more standard ball joint ends.
I’ve looked at this one and I’m still keeping it as a possibility. I could cut off the ends and weld my ball joints on. I’m a little reluctant to cut anything, that’s why I’m looking for other options.
   / Anyone make a ratcheting wrench for a cat 1 top link? #10
It can be done but i would cost about $350.... Looked into it, then walked away....Decided I didn't need it...
Seems like the are several $50 solutions posted here....
2017 Rogator RG1300B Dry Fertilizer Applicator (A56438)
2017 Rogator...
Unused 2025 CFG Industrial XZ20R Mini Excavator (A59228)
Unused 2025 CFG...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59575)
1999 TRANSCRAFT...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
