Anyone make a one man FEL lift?
   / Anyone make a one man FEL lift? #1
Fuddy1952
Elite Member
South Central Virginia
1973 Economy and 2018 John Deere 3038E
In a few weeks I need to install a large fan in a cupola.
My tractor FEL works great me getting in bucket cutting high limbs or extension ladder in it.
I raise it where I want, easy to climb up and in. This cupola project is 15 ft. up. Floor is concrete (level). With backhoe on that gives lots of rear weight plus I can use stabilizers.
Has anyone fabricated a working lift for bucket? I could simply strap a 4x8 sheet of plywood to it. Any ideas appreciated.
I'll have quite a bit of measuring, cutting, bolting things, wiring to do.
   / Anyone make a one man FEL lift? #2
Sorry to be contrary but I would rent some construction scaffolding...
   / Anyone make a one man FEL lift? #3
Some of use the IBC Tote cages for low projects. I use it for hedge trimming for example, but never more than 4' or so above ground. I wouldn't even consider it for 15'.
I thought of that also. The advantage of tractor I was thinking is I can load things on it, raise it up where I need it.
I forgot to mention I have a body safety harness I bought a few years ago that I could easily strap to a rafter.
Scaffolding probably safer, but this may be more versatile? Right now just getting ideas. Thanks!
   / Anyone make a one man FEL lift? #5
My loaders all have quick attaches for different buckets as well as forks.
This is the man lift I made for forks.
   / Anyone make a one man FEL lift? #6
I would use an IBC tote cage at minimum. I would also chain the bucket or forks (so it can't dump you out) and clamp a piece of angle to the loader lift cylinder (so that it can't drop).
Aaron Z
   / Anyone make a one man FEL lift? #7
You can rent a trailer mounted boom-lift pretty cheap. I like them so much that I bought one. 15' is not that high. Can you mount a standard 3pt boom pole to the loader bucket to get the fan up there and then configure the fan from a ladder ?
   / Anyone make a one man FEL lift? #8
you can just get a long 2x2 and duct tape it to the loader stick so you can operate it "remotely" :laughing:
Lots of ways to do it, I don't like working off of ladders much over about 8ft at my age.
2008 John Deere 310SJ Backhoe (A59213)
2008 John Deere...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
1604 (A58375)
1604 (A58375)
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59575)
2019 WABASH...
2016 Ford F-150 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
1998 Club Car Electric Cart (A56859)
1998 Club Car...
