Tires Anyone know wheel bolt pattern?
   / Anyone know wheel bolt pattern? #1
LS Tractor Owner
Super Member
Edgewood, NM
LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500
I am looking for the wheel bolt pattern for the MT125 and the XJ2025 tractors. I know 5 bolt, but can't get a precise spacing... 110mm, 112mm? If anyone has the specific pattern, I would greatly appreciate it.
Looking to get wheel spacers and there are a lot that are very close in size
   / Anyone know wheel bolt pattern? #3
actually it probably wont... the xj has 6 bolts...
Well, at least I found that the 2025 is 6 lug.... Hopefully someone has measured the mt125. They don't list the numbers in the manual. Too new to be listed on the net, not that I can find anyway. I'm being lazy, don't want to go pull a wheel off to measure it:p
   / Anyone know wheel bolt pattern? #5
5 on 4.5. Same as a standard garden tractor
That's what I first thought, but briefly just holding a tape measure across the bolts from center to center, they are only 4 1/4" across. Maybe 4 5/16". Converting to mm: 110mm / 112mm. There are spacers that are 108, 110, and 112mm. Very very close tolerances. I have trailer rims that are 5x4.5, and they don't fit. Had tried last summer when I had a tire off, but never actually measured the pattern.
   / Anyone know wheel bolt pattern? #7
Center hole may be smaller for a trailer rim. My wheel horse rims fit and look 100% the same when I eggedout the holes from not having the lug bolts tight enough. I went to the taper lug studs on all 4 after replacing the rim.
Could be, I'll have to go out and try again tommorow. I actually took my old wheelhouse 14 auto over to the neighbor to give to someone else. I might have to go retrieve it... Been sitting out in the field for about a year now.
What tapered studs did you get to use on the 125? Size /thread, and where did you get them?
24017 (A56859)
24017 (A56859)
2020 McLanahan 150 TPH USP Sand Plant (A55973)
2020 McLanahan 150...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
1994 International 3800 Bus (A54814)
1994 International...
40006 (A55788)
40006 (A55788)
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
