Tires Anyone know wheel bolt pattern?
   / Anyone know wheel bolt pattern? #1
LS Tractor Owner
Super Member
Edgewood, NM
LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500
I am looking for the wheel bolt pattern for the MT125 and the XJ2025 tractors. I know 5 bolt, but can't get a precise spacing... 110mm, 112mm? If anyone has the specific pattern, I would greatly appreciate it.
Looking to get wheel spacers and there are a lot that are very close in size
   / Anyone know wheel bolt pattern? #3
actually it probably wont... the xj has 6 bolts...
Well, at least I found that the 2025 is 6 lug.... Hopefully someone has measured the mt125. They don't list the numbers in the manual. Too new to be listed on the net, not that I can find anyway. I'm being lazy, don't want to go pull a wheel off to measure it:p
   / Anyone know wheel bolt pattern? #5
5 on 4.5. Same as a standard garden tractor
That's what I first thought, but briefly just holding a tape measure across the bolts from center to center, they are only 4 1/4" across. Maybe 4 5/16". Converting to mm: 110mm / 112mm. There are spacers that are 108, 110, and 112mm. Very very close tolerances. I have trailer rims that are 5x4.5, and they don't fit. Had tried last summer when I had a tire off, but never actually measured the pattern.
   / Anyone know wheel bolt pattern? #7
Center hole may be smaller for a trailer rim. My wheel horse rims fit and look 100% the same when I eggedout the holes from not having the lug bolts tight enough. I went to the taper lug studs on all 4 after replacing the rim.
Could be, I'll have to go out and try again tommorow. I actually took my old wheelhouse 14 auto over to the neighbor to give to someone else. I might have to go retrieve it... Been sitting out in the field for about a year now.
What tapered studs did you get to use on the 125? Size /thread, and where did you get them?
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A55315)
Midwestern...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A57880)
2016 FORD F-550...
2005 Freightliner Sportcoach Elite MH401TS 40ft. Class A Motorhome (A55853)
2005 Freightliner...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A56129)
2018 UTILITY VS2RA...
