Tires Anyone know wheel bolt pattern?
   / Anyone know wheel bolt pattern? #1
LS Tractor Owner
Super Member
Edgewood, NM
LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500
I am looking for the wheel bolt pattern for the MT125 and the XJ2025 tractors. I know 5 bolt, but can't get a precise spacing... 110mm, 112mm? If anyone has the specific pattern, I would greatly appreciate it.
Looking to get wheel spacers and there are a lot that are very close in size
   / Anyone know wheel bolt pattern? #3
actually it probably wont... the xj has 6 bolts...
Well, at least I found that the 2025 is 6 lug.... Hopefully someone has measured the mt125. They don't list the numbers in the manual. Too new to be listed on the net, not that I can find anyway. I'm being lazy, don't want to go pull a wheel off to measure it:p
   / Anyone know wheel bolt pattern? #5
5 on 4.5. Same as a standard garden tractor
That's what I first thought, but briefly just holding a tape measure across the bolts from center to center, they are only 4 1/4" across. Maybe 4 5/16". Converting to mm: 110mm / 112mm. There are spacers that are 108, 110, and 112mm. Very very close tolerances. I have trailer rims that are 5x4.5, and they don't fit. Had tried last summer when I had a tire off, but never actually measured the pattern.
   / Anyone know wheel bolt pattern? #7
Center hole may be smaller for a trailer rim. My wheel horse rims fit and look 100% the same when I eggedout the holes from not having the lug bolts tight enough. I went to the taper lug studs on all 4 after replacing the rim.
Could be, I'll have to go out and try again tommorow. I actually took my old wheelhouse 14 auto over to the neighbor to give to someone else. I might have to go retrieve it... Been sitting out in the field for about a year now.
What tapered studs did you get to use on the 125? Size /thread, and where did you get them?
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
2025 Electric Cart (A55853)
2025 Electric Cart...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A57880)
2019 INTERNATIONAL...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
