Anyone have a MechMaxx 3-pt stump grinder?
   / Anyone have a MechMaxx 3-pt stump grinder? #261
Did you pull the 2 pivot lock pins? I've only done a few myself, but it seems to me the pivot kind of controls the size of the bite. If you're taking too much, the forward force overcomes the weight of the unit and it tilts up and 'automatically' take a shallower bite. Am I wrong? Is there another purpose for this pivot point?
I stalled once with the pivot pins removed. It is not fool proof. But I work slower now and have not had it happen again.
   / Anyone have a MechMaxx 3-pt stump grinder? #262
I finally finished my BH work, removed the BH and installed the stump grinder. I had a heck of a job getting the PTO shaft onto the grinder shaft. Followed suggestions and recommendations here and finally got it on. I hope to never have to take it off again.
I found that none of the teeth were tightened to spec, that was fun getting them torqued to 160 ft-lbs.
- Does anybody have any suggestions to get the outside teeth torqued to spec? That silly 6" wrench they give you is a joke!!
- What is the preferred method to set the slip clutch to work properly? I loosened it to break it free but wasn't sure the best method to tighten it... except for just trial and error until it doesn't slip.
TIA
   / Anyone have a MechMaxx 3-pt stump grinder? #263
TIA
I lucked out, the pto slipped on the stump grinder shaft with no issues.
I double checked the torque on my teeth with a 2 foot cheater bar on a large breaker bar, all where tight. I double checked them after grinding a few stumps and they have remained tight.
As for the slip clutch, I set mine with a caliper. I started at 25 pto horses and it slipped too easily. I then set it up for the 30 pto horses that I have and I've only slipped it once when I bogged it down getting too aggressive on a large hardwood stump.
I've done at least 20 stumps with no stump grinder issues. The only issue I have is using the rear mounted implement for more than an hour sitting sideways watching the grinder do its job. It sucks to get old....
   / Anyone have a MechMaxx 3-pt stump grinder? #264
You're not using a torque wrench to set it? I would assume the 6" wrench is just to get them on and snugged up a bit.
   / Anyone have a MechMaxx 3-pt stump grinder? #265
I used a torque wrench for all cutters except the 4 on the outside edge, can't get my torque wrench/socket in there.
   / Anyone have a MechMaxx 3-pt stump grinder? #266
The wrench they include with the grinder is made to be an extension for your torque wrench for the teeth that you can't get a socket on. Not meant to be used by itself.
   / Anyone have a MechMaxx 3-pt stump grinder? #267
I read that in the instructions, but I have no idea how to attach/use that little wrench with my torque wrench.
   / Anyone have a MechMaxx 3-pt stump grinder? #268
Thanks for this thread. I've got some 30 stumps and my brother in law just down the road has 50. We had considered renting a walk behind for a week, but this might be a better option, and we would definitely be a lot less rushed...
I have a Kubota L4701DT with a gear shift transmission. It sounds like in Turtle 1, this has worked for some of you? That's my only concern. He has a MX7080 also with a gear and shuttle shift.
   / Anyone have a MechMaxx 3-pt stump grinder? #269
You just install the adapter on your torque wrench at a 90 degree angle (so as not to affect the amount of torque) and put the other end on the nut like any box-end wrench. You only need to use it on the nuts that can't be accessed by a regular socket.
   / Anyone have a MechMaxx 3-pt stump grinder? #270
What is this adapter you are talking about and how does it install on my torque wrench?
Kubota L45 (A57148)
Kubota L45 (A57148)
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
2012 MACK GU713 (A58214)
2012 MACK GU713...
2017 Ford F-250 (A55973)
2017 Ford F-250...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
