Anyone have a MechMaxx 3-pt stump grinder?
   / Anyone have a MechMaxx 3-pt stump grinder? #292
I've got 20 acres that is mostly trees. I'll be dealing with stumps for the rest of my life.
   / Anyone have a MechMaxx 3-pt stump grinder? #293
I have the original WM. It works well and as expected. That said, it's easy to try pulling it through the stump faster than the grinding wheel can chew, which results in the unit swinging from grinding at 90 degrees to more like 70 degrees. One time early on, I angled it sufficiently to separate the PTO shaft...and guarantee you'll only allow that to happen once!!!
Based on similar design, I'm guessing over feeding is likely a common situation to avoid with the MM also.
I would have paid the extra for the WM pro version if it had been available at the time, not even knowing if the shock actually works as described.
The other thing is the outside teeth get the most abuse. I wouldn't even mount the 6 or 8 (?) teeth closest to the hub, and just save them to swap as the outside teeth get chipped down (my stumps are rock magnets!).
Tighten up your 3-pt lift arms, playboy!
But yeah I always go to low range and barely touch the HST pedal, certainly easy to over-pull it and start bouncing around.
And agreed, those interior teeth will never see any action, kind of odd to have them at all.
   / Anyone have a MechMaxx 3-pt stump grinder? #295
I made mine out of 1/2" plate, 3/4" for the wheel, it doesn't bounce around.
I can't even hold my phone as steady as it is.
   / Anyone have a MechMaxx 3-pt stump grinder? #296
Good looking welds!
Although, I'm not sure that qualifies as a stump!
We're did you find your (carbide?) teeth?
   / Anyone have a MechMaxx 3-pt stump grinder? #297
I bought the pro version for my 4410. As far as I'm concerned the shock could use a heavier spring. It does help but could be more aggressive. It's probably ok for a smaller tractor. One day I will play around with some extra springs and see what happens.
   / Anyone have a MechMaxx 3-pt stump grinder? #299
What possesses people to join just to post nonsense?
Vermeer only makes industrial cutters. Unitaskers are better as implements.
   / Anyone have a MechMaxx 3-pt stump grinder? #300
Just curious if you know what the least expensive Vermeer unit costs.
For $1400, the MechMaxx might not be very good, but I doubt I will need to grind down more than 50 stumps in my lifetime as I am 75 now. Have done 7 so far and another 20 to go for my immediate needs. I figured doing the 30 or so stumps would have cost $3000 to have a contractor do it. $1400 seemed a good investment.
When I am done with it, I can likely sell it for $1000 or keep it. It will have more than paid for itself.
1696 (A58375)
1696 (A58375)
2001 Chevrolet Tracker Multipurpose Vehicle (MPV), VIN # 2CNBJ734816938409 (A57453)
2001 Chevrolet...
LOT: (1) Shelf of Takeuchi & Donaldson Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (1) Shelf of...
2315 (A58376)
2315 (A58376)
2019 DODGE RAM LARAMIE 5500 FLATBED (A58214)
2019 DODGE RAM...
Mini Excavator (A55787)
Mini Excavator...
