Anyone else having this problem on a B7800 or Bx23
   / Anyone else having this problem on a B7800 or Bx23 #1
1TMatthews
Dunstable,MA
Kubtoa B3200
Hello,
Just got my B7800 back from a 50hr service and an altenator installed. The tractor is an awsome machine. I was using it the other day and realized that the float wasn't working and that when I gave it down pressure it would go then release. I guy that I work with has a bx23 and his float isn't working either and his machine is newer also. Any ideas on the cause.
   / Anyone else having this problem on a B7800 or Bx23 #2
Here is a thread from this weekend on a similar problem. I don't know if it is fixed. But you should be find some help in it.
Click Here
   / Anyone else having this problem on a B7800 or Bx23 #3
My BX22 did that a few times last year. I just held the joystick to the max in any position and it worked....Not a "fix it" but it worked. I think it had to purge air out or something...
   / Anyone else having this problem on a B7800 or Bx23 #4
Had the same problem with L3830HST w/LA723. Dealer fixed it twice under warranty.
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2014 GENIE...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
1261 (A50490)
1261 (A50490)
