Anyone else having this problem on a B7800 or Bx23
   / Anyone else having this problem on a B7800 or Bx23 #1
1TMatthews
Bronze Member
Dunstable,MA
Kubtoa B3200
Hello,
Just got my B7800 back from a 50hr service and an altenator installed. The tractor is an awsome machine. I was using it the other day and realized that the float wasn't working and that when I gave it down pressure it would go then release. I guy that I work with has a bx23 and his float isn't working either and his machine is newer also. Any ideas on the cause.
   / Anyone else having this problem on a B7800 or Bx23 #2
Here is a thread from this weekend on a similar problem. I don't know if it is fixed. But you should be find some help in it.
Click Here
   / Anyone else having this problem on a B7800 or Bx23 #3
My BX22 did that a few times last year. I just held the joystick to the max in any position and it worked....Not a "fix it" but it worked. I think it had to purge air out or something...
   / Anyone else having this problem on a B7800 or Bx23 #4
Had the same problem with L3830HST w/LA723. Dealer fixed it twice under warranty.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2018 CATERPILLAR 336FL EXCAVATOR (A51222)
2018 CATERPILLAR...
71058 (A49346)
71058 (A49346)
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
71056 (A49346)
71056 (A49346)
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
