Anybody with a CK27HST
   / Anybody with a CK27HST #21
Backhoes can be plumbed differently, and are depending on dealer and cost. And there are two different remote kits. I think one kit has detents in both positions, and the other has detent in one while the other position springs back to N when released (but the hydraulic pressure is held). N does mean neutral, but not zero pressure (not float). I have the latter version on mine that controls a rear set of remotes that can be used for anything. I use them for my backhoe and a hydraulic toplink. My 3PH works only with the valve set to N. I've also seen a backhoe plumbed from the loader block on a CK20 and there is some sort of bypass valve that has to opened and closed at the block. I think I've read about the bigger CK's having this setup too. Not sure of all the details on it. Though, I think it's done to save the cost of adding the remote.
For the OP, be happy. You have a rear remote setup. Now get a backhoe, log splitter, hydraulic toplink, hyd down pressure post hole digger, hyd steerable snowblower, etc. and put it to good use. Then you'll want to add a second remote for hyd angle and toplink at the same time:)
Thanks for the replies, people.
Cement mixer with hydraulic top link coming soon.
2005 Sterling Acterra Tender Truck (A56435)
2005 Sterling...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
2014 Walker Compactor (A55787)
2014 Walker...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A57880)
2018 VOLVO VNL...
